Missing a bit
Results 1 to 2 of 2
Thread: Missing a bit
    Aug 2009
    Paso Robles California
    Default Missing a bit
    I need a fresh set of eyes on this. Im trying to send 5c which is 01011100
    it is not sending correctly. It is sending 0111010 looking at the scope which is almost correct but it is missing the second 0 on the left. And yes I know it is inverted and this is correct. I need this 0, so it should look like 00111010 on the scope I have this working using bit banging and have compaired the two pattern's the bit bang works great this missing 0 does not.
    For Bits = 0 to 7
    Command_bit = value.0[Bits]
    if command_bit = 1 then
    low portb.2
    input portb.2 'if command_bit = 0 then input portb.2
    pauseus 104
    next
    Aug 2009
    Default missing a bit
    I have it working now I changed the pauseus time to a lower setting as the program overhead was giving me too long a pauseus time and putting my bits out of range
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 10:31
  4. PICBasic newbie problem
    By ELCouz in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 00:55
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 01:07
