explanation about HSERIN command!
Results 1 to 9 of 9
    Can you tell us what you are sending and the result?
    Also, how is your hardware set up?
    Jul 2009
    hi mackrackit,
    three PICs are attached to a master PIC all of type 16F877A using RS-485.
    configuration without leds lcd definitions :
    * MASTER PIC:
    Include "Modedefs.bas"
    DE_OR_RE VAR PORTC.5
    RS232_DEBUG_PIN VAR PORTB.5
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_SPBRG 25
    DEFINE HSER_BAUD 2400
    DEFINE HSER_CLROERR 1
    OPTION_REG.7 = 0
    CMCON = 7
    ADCON1 = 7
    B0 = 0
    SLave PIC:
    define HSER_TXSTA 20h
    define HSER_SPBRG 25 'SPBRG 2400
    DEFINE OSC 4 ' We're using a 4 MHz oscillator
    DEFINE ADC_BITS 8 ' Set A/D for 8-bit operation
    DEFINE ADC_CLOCK 1 ' Set A/D clock Fosc/8
    DEFINE ADC_SAMPLEUS 50 ' Set A/D sampling time @ 50 uS
    TRISA = %11111111
    PORTA = %00000000
    OPTION_REG.7 = 0
    CMCON = 7
    ADCON1 = 0
    i'm sending from another PIC 1's and 0's which represent the status of my sensors it's attached on analog pins(four sensors for each slave PIC).
    The result should be also received as 1's and 0's as sent in sequence.
    thanks for help...
    Have you enabled/disabled the TX pin?
    If you are not familiar with 485 this is a good read
    http://www.bb-elec.com/tech_articles...f_contents.asp
    And buried in this thread is some code.
    http://list.picbasic.com/forum/messa...html?996705165
    Post your whole code so we can take a look.
    Jul 2009
    hi mackrackit,
    sorry for being late but i had some wrok to do the previous days..
    here're the full code attached down, so it'll be easier to detect the errors.
    yea, i'm already receiving and sending but my problem is the incorrect received values.
    thanks alot...
  1. explanation on I2C command (PBP)
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 12th May 2014, 06:30
  2. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  3. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
  5. HSERIN command - Still searching for answers
    By electronicsuk in forum mel PIC BASIC Pro
    Last Post: - 26th December 2003, 10:28
