explanation about HSERIN command!
Results 1 to 9 of 9
    Jul 2009
    Default explanation about HSERIN command!
    dear all,
    IF i send four digits refer to the status of my LEDs from several PICs(18F877A) and recieve them using HSERIN command one after another using subroutines..
    May this affect accuracy of the sent data? are there any further configuration for the HSERIN command in this case? Is there a way to clear the buffer after each sending ( because it keeps showing me the same result each time i send new values).
    thank you,,
    Hi DeViLa_Q8,
    Hard to answer as to what more you need, as you did not show us how you set up the hserin to work. As far as clearing the buffer goes, read it into another variable and then zero it before the next read.
    example:
    char var byte
    dummy var byte
    HSERIN char
    info = char
    char = 0
    ' . . . . do something with info . . LCDOUT #info ?
    Maybe this will help?
    From the manual
    As the hardware serial port only has a 2 byte input buffer, it can easily overflow if characters are not read from it often enough. When this happens, the USART stops accepting new characters and needs to be reset. This overflow error can be reset by toggling the CREN bit in the RCSTA register. A DEFINE can be used to automatically clear this error. However, you will not know that an error has occurred and characters may have been lost.
    *** DEFINE HSER_ CLROERR*** 1
    To manually clear an overrun error:
    *** RCSTA. 4 = 0*
    *** RCSTA. 4 = 1
    Jul 2009
    Hi DeViLa_Q8,
    example:
    char var byte
    dummy var byte
    HSERIN char
    info = char
    char = 0
    dear Joe S.
    I'm working on this code using the new ideas and i hope it'll work anyway In case the idea was not that obvious
    the first HSERIN will be like this,
    HserIN [WAIT("OK"),TARGET]
    IF TARGET ="A" THEN gosub check1
    after it'll compare the result then it'll perform subroutines attached to each target and in this subroutine there's another HSERIN which is,
    check1:
    HSERIN [X,Y,Z,M,N] ' analog
    statements
    i traced my code it working great and i tested it on LCDs except the previous HSERIN result it's totally not correct.i hope it becomes clear now.
    thanks for yr help,
    Jul 2009
    From the manual
    *** RCSTA. 4 = 0*
    *** RCSTA. 4 = 1
    dear mackrackit,
    I changed the code to manually clear the buffer,but unfortunately it gives the same incorrect result as before .
    thank you for yr help,
    dear
    Can you tell us what you are sending and the result?
    Also, how is your hardware set up?
    Jul 2009
    hi mackrackit,
    three PICs are attached to a master PIC all of type 16F877A using RS-485.
    configuration without leds lcd definitions :
    * MASTER PIC:
    Include "Modedefs.bas"
    DE_OR_RE VAR PORTC.5
    RS232_DEBUG_PIN VAR PORTB.5
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_SPBRG 25
    DEFINE HSER_BAUD 2400
    DEFINE HSER_CLROERR 1
    OPTION_REG.7 = 0
    CMCON = 7
    ADCON1 = 7
    B0 = 0
    SLave PIC:
    define HSER_TXSTA 20h
    define HSER_SPBRG 25 'SPBRG 2400
    DEFINE OSC 4 ' We're using a 4 MHz oscillator
    DEFINE ADC_BITS 8 ' Set A/D for 8-bit operation
    DEFINE ADC_CLOCK 1 ' Set A/D clock Fosc/8
    DEFINE ADC_SAMPLEUS 50 ' Set A/D sampling time @ 50 uS
    TRISA = %11111111
    PORTA = %00000000
    OPTION_REG.7 = 0
    CMCON = 7
    ADCON1 = 0
    i'm sending from another PIC 1's and 0's which represent the status of my sensors it's attached on analog pins(four sensors for each slave PIC).
    The result should be also received as 1's and 0's as sent in sequence.
    thanks for help...
    Have you enabled/disabled the TX pin?
    If you are not familiar with 485 this is a good read
    http://www.bb-elec.com/tech_articles...f_contents.asp
    And buried in this thread is some code.
    http://list.picbasic.com/forum/messa...html?996705165
    Post your whole code so we can take a look.
    Jul 2009
    hi mackrackit,
    sorry for being late but i had some wrok to do the previous days..
    here're the full code attached down, so it'll be easier to detect the errors.
    yea, i'm already receiving and sending but my problem is the incorrect received values.
    thanks alot...
  1. explanation on I2C command (PBP)
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 12th May 2014, 06:30
  2. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  3. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
  5. HSERIN command - Still searching for answers
    By electronicsuk in forum mel PIC BASIC Pro
    Last Post: - 26th December 2003, 10:28
