load .hex file in PIC with hyperterminal
Results 1 to 9 of 9
    Aug 2009
    Default load .hex file in PIC with hyperterminal
    Hi all!!
    I am doing a project with PIC16F874. I have the .asm code, and I have create a project with MPLAB. Then, I have built it successfully and i have generated the .hex file!!
    So, now, I need to load this .hex file in the PIC. I want to do it using the hyperterminal because i haven't any bootloader.
    I have configure hyperterminal with 9600bps, 8 - N - 1. then I connect the pic to the pc with a RS232 wire and then i turn on the pic. So, the hyperterminal shows the last program loaded and that the pic has jumped to the code.
    In order to load my file, i try to transfer the file, but it doesnt go!
    Can you help me, please??
    Thumbs down
    No luck in this way !!!
    You do need a programmer in all cases ...
    - You program a boot loader WITH the Programmer ... then you use Hyperterm, i.e.
    OR
    - You program your chip with the programmer.
    in both cases you DO need a programmer !!!
    Have a look to the cost of a PicKit2 ... and do not hesitate !!!
    OR you can try PICAXE Chips ... that have a pre-programmed bootloader ( sort of ! )
    Aug 2009
    Thanks a lot Acetronics!!!
    what do you mean with "programmer". I have used the MPLAB IDE.
    How do i program the boot loader?? and how do i use the hyperterminal??
    MPLAB is an IDE. It is a place to write the code.
    When the code is made into a HEX file a compiler is used, MPASM is the one MPLAB uses.
    A programmer is hardware to place the code on the chip. Certain voltage levels have to be met on certain pins for the chip to accept the file.
    Like Alan said, look at the PicKit2. Very nice.
    http://www.microchip.com/stellent/id...cName=en023805
    Aug 2009
    Thanks mackrackit.
    i understand it, but i have in the board an integrated circuit to implement it. This is: the MAX232, and then i have configured ports number 6 and 7 as input and output.
    with this, i suppose that i can communicate the pic with the pc to load the hex file...
    but how do i do this?
    May 2008
    Italy
    Read How easily to build your own programmer @ this link:
    http://www.rentron.com/Myke4.htm
    This will help you in understanding the programmer subject.
    Al.
    Quote Originally Posted by irenuska23 View Post
    Thanks mackrackit.
    You have two pins on the pic labeled PGD and PGC, these are the pins the programmer uses to communicate with the chip. If these are the pins the 232 is connected to you are probably OK. You will need to "bug in" a connection of some kind between the PIC and the 232 to go to the programmer.
    The other pin used by the programmer is labeled MCLR. It is best not to have this pin connected to anything during programming. If it is connected to something it will need to be isolated with a diode. Higher voltage is applied to this pin to place the PIC in programming mode.
    So what you have is not going to work to get the first program into the chip as Alan mentioned. It might work after a boot loader is used.
    Read the link Al provided but I do not recommend building one. Unless you are wanting to build programmers. If you want to write code and program a chip then buy a programmer.
    Beware of the ebay stuff though. The money you save will be made up for in time and headaches.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Send binary file to pic over pc serial port
    Last Post: - 3rd May 2011, 13:47
  3. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  4. Replies: 67
    Last Post: - 8th December 2009, 02:27
  5. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
