Pretty New and need help please
Results 1 to 4 of 4
    Apr 2009
    Question Pretty New and need help please
    Hi Everyone,
    I'm using a PIC16F877 chip in this project.
    I'm still pretty new at PIC programming and there's alot I don't know or understand!
    About 34 or 35 lines below, you will see *** ;ADCON1=%00000011 and ;ADCON1=%00000010 ***
    The reason these lines are marked as notes ( is because I can not get the results I expected!
    I'm trying to use A2D Channels 0 and 1. Channel 0's input ranges from 0 to + 5 VDC.
    Channel 1's input ranges from 0 to + 1 VDC.
    I'm trying to use a very small input from a current shunt (in Millivolts)
    100 Millivolts Max, and display this current on the LCD. With the Vref set
    at + 1 VDC, I think I should be able to see current changes of 4 Amps.
    Is there a minumum Vref voltage? I've looked over the Datasheet but
    have not found anything about Vref minimums. Ideally, I would set
    Vref at .255 VDC.
    **** Is what I'm trying to do even possible?****
    ****Any help will really be appreciated!****
    '* Name : New_PWM.bas *
    '* Author : Roddy Wayne *
    '* Notice : Copyright (c) 2008 *
    '* : All Rights Reserved *
    '* Date : 08/09/2008 *
    '* Version : 1.0 *
    '* Notes: *
    '* A PWM for running a Hydrogen Generator *
    CLEAR ;always start with clear
    DEFINE OSC 4 ;define oscillator speed
    DEFINE ADC_BITS 8 ; Sets number of bits in result
    DEFINE ADC_CLOCK 3 ; Sets clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ; Sets sampling time in uS
    define DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    define DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 1000
    Low PORTE.2 ;makes low for write only
    TRISA = %00001111 ;sets 0, 1, 2, and 3 as porta inputs (A to D's & ref's)
    TRISB = %00111111 ;sets bits 6 & 7 portb pins as outputs, 0 thru 5 as inputs
    TRISC = %10111111 ;sets port c.6 for serial output
    TRISD = %00000011 ;sets PORTD 0,1, lines to inputs, rest to outputs
    TRISE = %00000000 ;sets all PORTE lines to outputs
    potpos var BYTE ;potpos is 8 bit
    cellamps VAR BYTE ;cellamps is 8 bit
    A2D_V VAR BYTE ;Created A2D_V Value to store result
    A2D_V2 Var BYTE ;Created A2D_V2 Value to store result
    ;ADCON1=%00000011 ;Sets the Analog to Digital control register to 4 Channels
    ;with Vref+ and Ground as the references!
    ;This Vref is + 1 VDC
    ;ADCON1=%00000010 ;Sets the Analog to Digital control register to 5 Channels
    ;with +5 VDC and Ground as the references!
    Start:
    If portc.0 = 0 then portb.6 = 0 'If pin 15 is low, make pin 39 low
    If Portc.0 = 1 then portb.6 = 1 'If pin 15 is high, make pin 39 high
    'When Pin 39 goes high, this turns the
    'pump on! I'm using a Darlington pair
    'to do this (Part # TIP120) It also turns
    'on the "Pump On" LED.
    If portc.3 = 0 then portb.7 = 0 'If pin 18 is low, make pin 40 low
    If portc.3 = 1 then portb.7 = 1 'If pin 18 is high, make pin 40 high
    'When Pin 40 goes high, the "Low Tank
    'Water" LED is turned on!
    ADCON1=%00000010 '?? Setup to read analog inputs
    ADCIN 0, A2D_V 'Read channel 0 to A2D_Value
    Pause 50
    potpos= A2D_V
    Debug 14, 1, "Pot Position =", 32, DEC2 potpos, 13
    Pause 50
    ;ADCON1=%00000011
    Pause 50
    ADCIN 1, A2D_V2 'Read channel 1 to A2D_V2 Value
    cellamps= A2D_V2
    Debug "Cell Amps =", 32, DEC2 cellamps, 13
    Pause 50
    HPWM 2, 127, 17500 'Output is a 17.5 Khz, 50% duty cycle (pin 16)
    ;ADCON1=%0000010
    Pause 100
    ADCIN 0, A2D_V ' Read channel 0 to A2D_Value
    potpos= A2D_V
    If (potpos <=%00011100)and(potpos <=%00111111) then percent_40
    potpos= A2D_V
    If (potpos <=%01000000)and(potpos <=%01011001) then percent_60
    potpos= A2D_V
    If (potpos <=%01011010)and(potpos <=%01110011) then percent_80
    potpos= A2D_V
    If (potpos <=%01110100)and(potpos <=%01111110) then percent_100
    If (potpos >=%01011110) Then percent_100
    'This assures that any potpos >= 11110110, will keep the output
    'at 100%, where it used to go back to 50%!!!
    percent_40: 'Asking for 40% On / 60% Off
    HPWM 1, 102, 17500 'Output is a 17.5 Khz, 40% duty cycle (pin 17)
    Pause 100
    DEBUG "PWM = 40%High/60%Low", 32, 32, 1
    Pause 400
    GoTO start
    percent_60: 'Asking for 60% On / 40% Off
    HPWM 1, 153, 17500 'Output is a 17.5 Khz, 60% duty cycle (pin 17)
    Pause 100
    DEBUG "PWM = 60%High/40%Low", 32, 32, 1
    Pause 400
    GoTO start
    percent_80: 'Asking for 80% On / 20% Off
    HPWM 1, 204, 17500 'Output is a 17.5 Khz, 80% duty cycle (pin 17)
    Pause 100
    DEBUG "PWM = 80%High/20%Low", 32, 32, 1
    Pause 400
    GoTO start
    percent_100: 'Asking for 99% On / 1% Off
    HPWM 1, 253, 17500 'Output is a 17.5 Khz, 100% duty cycle (pin 17)
    Pause 100
    DEBUG "PWM = 99%High/01%Low", 32, 32, 1
    Pause 400
    GoTO start
    It looks doable...
    ADCON1 only needs setup in one place of your code. Normally near the beginning.
    You may want to read the separate ADC channels into separate variables. The deal with them later.
    Read this page, and everything else on Bruce's site for that matter, the VREF is talked about here.
    http://www.rentron.com/PicBasic/LM34.htm
    Apr 2009
    Question
    Thanks for responding Mackracit!
    Boy, I sure do not understand this!
    I've looked at this link before
    and thought that ADCON1=%00000011 is used when using an external reference voltage and ground with up to 4 analog input channels.
    In looking at the datasheet, it looks to me that ADCON1=%00000010 can be used for up to 5 input channels
    using + 5 VDC and ground as the reference voltage.
    So, I guess what I am asking you is, how can ADCON1=%00000011 be used to read both channels accurately?
    It seems to me that I'd have to switch between ADCON1=%00000011 and ADCON1=%00000010 to be able to do this????
    I think I have two separate variables to store the two A2D channels, do I not?
    Now I am totally confused!
    Confusion is good
    I missed the second 2 on one of your variables.... ooppsss. You do have two separate.
    ADCON1 is used to set the pins to be either digital or analog and if and external VREF is used. The data sheet gives the different options, sometimes the option you want is not an option...
    So no switching after it is set. You have to decide on the pins ahead of time.
