3V Voltage Regulator with Shutdown Feature
Results 1 to 9 of 9
    Miami, Florida USA
    Default 3V Voltage Regulator with Shutdown Feature
    I bought this nice 3V voltage regulator to use in my PIC projects. It has very low supply voltage and good overall characteristics. But, the feature that I probably like the most is the power saving shutdown mode. If the shutdown pin is high then the regulator is enable, and if this pin is low then the regulator is in shutdown mode.
    Now come the questions. The datasheet says that this shutdown pin can be controlled from a microcontroller port. Nice, but then how do you make this port high before there is any power in the circuit for the PIC to come up? Remember the shutdown pin has to be high. And when you make this shutdown pin low, it has to stay low otherwise the regulator won't be in power saving mode. Does anybody know of an easy way to make this work?
    Miami, Florida USA
    Have a momentary switch to manually power the regulator. Hold the switch until the PIC boots.
    Miami, Florida USA
    Thanks mackrackit for your idea, but I really want to use this feature to shutdown the circuit if it hasn't been used for a certain amount of time. I want to use it like a "SLEEP" command. This regulator uses a current near zero (0.5 uA max) when in power saving mode, so that would make it ideal for battery operated applications.
    Robert,
    Miami, Florida USA
    mackrackit,
    I'm sure there has to be a way to control this shutdown pin with circuitry without holding a pushbutton. Thanks anyways for your idea.
    I misunderstood,
    you want the pic or some circuit to start the rgulator?
    I was thinking you were just going to have the pic do the shut down.
  1. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 21:32
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 20:20
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  4. Help with DS2436 Voltage monitor
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 30th October 2006, 17:39
  5. Low Voltage Detection
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 19:29
