SDHC (FAT32 for SD cards)
Results 1 to 23 of 23
    Sep 2009
    Default Re: SDHC (FAT32 for SD cards)
    I have 2 SD cards 2GB and 16GB, both formated as FAT32. 2GB works fine, 16 fails initialization.
    It fails to select FAT32
    	Select Case (DISK_buffer[450])
    		Case $01
    			DISK_type = FAT12 : FAT_error = CE_CARDFAT12
    		Case $04, $06, $0e
    			DISK_type = FAT16
    		Case $0b, $0c
    			DISK_type = FAT32
    		Case Else
    			FAT_error = CE_BAD_PARTITION
    	End Select
    Goes straight to FAT_error = CE_BAD_PARTITION
    Tried to select FAT32, but then fails later..
    As far as I understand up to 32GB should be supported.
    Any update on that?
    Aug 2011
    What IS the partition type value in DISK_buffer[450]?
    Looking at that byte isn't really the way to determine FAT16/FAT32...
    Sep 2009
    I think $72. I'll check later.
    But that is way they do it... I'm not familiar at all with anything regarding SD.
    I was hoping that I could just use module as is...
    First I edited my project from 2012, and it would create file on sd card, but wouldn't write nothing into file. That was case with both cards(2 and 16 gb)...
    Then I remove all files, and download new. First I get it to work with FAT16(2gb card), then replace INCLUDE "SDFS.pbp" with INCLUDE "sdfshc32d.pbp". Tried 2GB formated as fat 16 and fat32 and it worked. Then tried 16gb fat32 and then get it to fail at FSInit, error 6 (CE_INIT_ERROR Con 6 ' An initialization error has occured)
    What else I could check and report back, if you are interested in improving sdfshc32d.
    Sep 2009
    Now fails here
    	For SDC_timeout1.lowbyte = $ff To 0 Step -1
    		SDC_sector_addr = 0 : Gosub SectorRead	' Long SDC_sector_addr is the sector to read.  Returns Byte SDC_status.
    		If (SDC_status = sdcValid) Then SDC_timeout1 = 0	' Got a valid response, end the loop.
    	Next SDC_timeout1.lowbyte
    	If (SDC_status != sdcValid) Then SDC_status = sdcCardNotInitFailure : Goto InitError
    	Return			' Return Byte SDC_status.
    SDC_status=2
    SDC_response=$A9
    FAT_error=6
    I don't have answers, only more questions:
    • Are you sure it's even a coding issue?
      Doesn't going over 2GB put you into another category of card speeds?
      Are PIC18Fs even fast enough to process these I/Os?
    For example:
    https://www.spypoint.com/en/blog/41/...-types-classes
    I'm sure the larger/faster/newer PICs can do it, but I know nothing about them except Microchip advertisements.
