SDHC (FAT32 for SD cards)
Results 1 to 23 of 23
    Nov 2006
    Default Re: SDHC (FAT32 for SD cards)
    I'm having the same problem described at the end of this (dead?) thread. Was there ever a solution? BTW, I had it working for FAT16 - so hardware is probably OK.
    Thx
    FAT16 works. For 32 there is nothing good up to this moment. Also other compilers are good only at 16 as far as I know.
    Nov 2006
    But what about the posts above. Looks like some folks had a FAT32 library working. Am I missing something?
    Officially there is no library for FAT32 by Melabs. All others are experimental and with no warranty that it will not corrupt your card.
    You said on post #14 you are having problems. Same #13. Same with me.
