Hello Guys,
i am new with sd cards and i have read almost all posts about them and seriously only you are talking about FAT32 format and have the files.Can anyone guide me?? I am not asking to get free code or something im just stuck here . I have tried just to initialize the card but i failed. Iam using 18F26K22 hardware SSP1 module for communicating with the card and hardware EUART to debug the programm. I dont want to use the SD_WE and SD_CD and i simply didn't connect them.
Here is what i tried so far but the programm is stucked at "Gosub FSinit" command.
'DEFINES  DEFINES  DEFINES  DEFINES  DEFINES  DEFINES  DEFINES  DEFINES  DEFINES
include "modedefs.bas"
include "fuses_18f26k22.bas"
include "eusart_defines_ep7.bas"
DEFINE OSC 32
'VARIABLES  VARIABLES  VARIABLES  VARIABLES  VARIABLES  VARIABLES  VARIABLES
i var byte
'  COUNTERS  COUNTERS  COUNTERS  COUNTERS  COUNTERS  COUNTERS  COUNTERS COUNTERS
'  FLAGS  FLAGS  FLAGS  FLAGS  FLAGS  FLAGS  FLAGS  FLAGS  FLAGS  FLAGS  FLAGS
'  ARRAYS  ARRAYS  ARRAYS  ARRAYS  ARRAYS  ARRAYS  ARRAYS  ARRAYS  ARRAYS  ARRAY
'  PORTS  PORTS  PORTS  PORTS  PORTS  PORTS  PORTS  PORTS  PORTS  PORTS  PORTS
'  REGISTERS  REGISTERS  REGISTERS  REGISTERS  REGISTERS  REGISTERS  REGISTERS
TRISA= %00000000
TRISB= %00000011
TRISC= %00010000
ANSELA=0
ANSELB=0
ANSELC=0
include "SDFSHC32original.bas"
SDC_UseHardSPI = TRUE
goto Init
'ISR   ISR   ISR   ISR   ISR   ISR   ISR   ISR   ISR   ISR   ISR   ISR   ISR
'   Initialization     Initialization      Initialization      Initialization
Init:
  PORTB= 0
  PORTA= 0
  PORTC= 0
  FAT_FileName[0] = "N"
  FAT_FileName[1] = "A"
  FAT_FileName[2] = "M"
  FAT_FileName[3] = "E"
  FAT_FileName[4] = "S"
  FAT_FileName[5] = " "
  FAT_FileName[6] = " "
  FAT_FileName[7] = " "
  FAT_FileName[8] = "T"
  FAT_FileName[9] = "X"
  FAT_FileName[10]= "T"
  Hserout ["Init routine: OK!",13,10]
  for i=0 to 10
    Hserout [fat_filename[i]]
  next i
    Hserout [13,10]
  i= 0
  PAUSE 100
' Main Programm  Main Programm  Main Programm  Main Programm  Main Programm
  Hserout ["LoopCount= ",dec i," FAT_error= ",dec fat_error," SDC_status= ",_
  dec SDC_status," SDC_response= ",dec SDC_response,13,10]
  Gosub FSInit
  pause 10
  Gosub FSInit
  i= i+1
goto Main
'Subroutines  Subroutines  Subroutines  Subroutines  Subroutines  Subroutines
and my SDFSHC32D.bas file is attached.
SDFSHC32Original.bas
Im looking forward for an answer, Kostas.
