PIC Beginner - Infrared Receiver and IR Protocol
Results 1 to 18 of 18
Threaded View
  1. #15
    Dec 2005
    Quote Originally Posted by komoe01 View Post
    Please let me know:
    1. How to calculate (pulse>100) is logic 1.
    2. and PULSIN_MAX 1140 . why do you use 1140
    I normally use RF where pulses & spaces are slightly different. I did the conversions to IR quickly, from memory and doing the math in my head so both figures are a bit on the high side.
    IR transmitters (i.e. remotes) that used the NEC chip actually used numbers of carrier cycles as the unit of time rather than absolute number of µS. They were also battery operated so there could be some variation due to voltage variations. It is recommended to allow ±20% although that's probably generous with more modern remotes (the protocol has been around for about 40 years).
    120% of 900 = 1080 instead of 1140.
    With this method we are only able to measure the spaces which can be 0.56mS or 1.125mS. We just want to determine whether it is one or the other. A figure about halfway between the two values should work so 85 might be better than the 100 I used.
    The NEC protocol is used by many manufacturers and you will encounter some that do not adhere exactly to the values given in the NEC datasheet so you need to build in a little flexibility.
  1. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  2. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 20:02
  3. Infrared Receiver
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 8th December 2006, 01:03
  4. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 17:12
  5. Can this IR Xmitter/Rcvr be improved?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 24th August 2005, 11:27
