Leds on/off
Results 1 to 17 of 17
Thread: Leds on/off
    Talking the car without engine ...
    I do not remember the 16F84 had an internal oscillator ...
    none aboard the ( censored ) simulation ...
    But I'm just getting 53 ...
    PS: Ahhhhh ... Da Vinci Code !!!!
    May 2007
    Republic Serbia
    16F84 and 16F84A do not have internal OSC...
    Jan 2006
    Istanbul
    Quote Originally Posted by phoenix_1 View Post
    On his simulator, it is not required to connect crystal or resonator etc.
    It will run normally as if those were connected.
    Hi, Sayzer
    I do not want to use sims ... lol
    BTW :
    IF PORTB.0=0 then
    HIGH PORTB.4
    WHILE PORTB.0=0 : Wend : pause 50
    IF PORTB.0=0 then
    LOW PORTB.4
    This kind of structure can't work properly ... as the second part never can be reached !!! ( or toggling button in less than 1µs ... )
    Button state AND its corresponding output state must be tested at the same time ... to take the appropriate action.
    Talking
    Sorry ...
    was not 1µs but 50 ms ...
    but result is the same !!!
    chatchai's Avatar
    chatchai Guest
    Red face I am speek Thai and my english very bad... but my example..
    ' Test I/O Ports Input and Output
    SW1 var PORTB.0
    SW2 var PORTB.1
    SW3 var PORTB.2
    SW4 var PORTB.3
    LED1 VAR PORTD.0
    LED2 VAR PORTD.1
    LED3 VAR PORTD.2
    LED4 VAR PORTD.3
    i var byte
    DEFINE OSC 48
    '------- Initial IO Ports -------
    TRISB = $FF
    TRISD = 0
    CMCON = 0
    ADCON1 = 7
    '------- Main Function -------
    LED1 = SW1
    LED2 = SW2
    LED3 = SW3
    LED4 = SW4
    Jan 2008
    Try this
    start:
    IF PORTB.0=0 then
        toggle PORTB.4
    IF PORTB.1=0 then
        toggle PORTB.5
        WHILE PORTB.1=0 : Wend : pause 50
    IF PORTB.2=0 then
        toggle PORTB.6
        WHILE PORTB.2=0 : Wend : pause 50
    IF PORTB.3=0 then
        toggle PORTB.7
        WHILE PORTa.3=0 : Wend : pause 50
    goto start
  1. Run a string of LEDs from the mains
    Last Post: - 1st October 2009, 18:55
  2. Replies: 14
    Last Post: - 26th April 2007, 15:12
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  4. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 21:02
  5. Replies: 5
    Last Post: - 16th February 2005, 11:57
