If you are simulating it as seen in your schematic, then the simulator might be giving false simulation because you do not have resistors on the leds.
I say this is 98% possibility of the error you are getting.
I do not remember the 16F84 had an internal oscillator ...
none aboard the ( censored ) simulation ...
But I'm just getting 53 ...
PS: Ahhhhh ... Da Vinci Code !!!!
Hi, Sayzer
I do not want to use sims ... lol
BTW :
This kind of structure can't work properly ... as the second part never can be reached !!! ( or toggling button in less than 1µs ... )
IF PORTB.0=0 then
HIGH PORTB.4
WHILE PORTB.0=0 : Wend : pause 50
IF PORTB.0=0 then
LOW PORTB.4
Button state AND its corresponding output state must be tested at the same time ... to take the appropriate action.
Sorry ...
was not 1µs but 50 ms ...or toggling button in less than 1µs ...
but result is the same !!!
' Test I/O Ports Input and Output
SW1 var PORTB.0
SW2 var PORTB.1
SW3 var PORTB.2
SW4 var PORTB.3
LED1 VAR PORTD.0
LED2 VAR PORTD.1
LED3 VAR PORTD.2
LED4 VAR PORTD.3
i var byte
DEFINE OSC 48
'------- Initial IO Ports -------
TRISB = $FF
TRISD = 0
CMCON = 0
ADCON1 = 7
'------- Main Function -------
LED1 = SW1
LED2 = SW2
LED3 = SW3
LED4 = SW4
