Leds on/off
Results 1 to 17 of 17
Thread: Leds on/off
    Default Leds on/off
    Hello forum friends,
    I have 4 buttons connected to PORTB and 4 LEDs to PORTB, I turn on and off with the same button for the LED but independently, with this code does not work properly any suggestions?.
    start:
    IF PORTB.0=0 then
        HIGH PORTB.4
        WHILE PORTB.0=0 : Wend : pause 50
    IF PORTB.0=0 then
        LOW PORTB.4
    iF PORTB.1=0 then
        HIGH PORTB.5
    IF PORTB.1=0 then
        LOW PORTB.5
    iF PORTB.2=0 then
        HIGH PORTB.6
    IF PORTB.2=0 then
        LOW PORTB.6
    iF PORTB.3=0 then
        HIGH PORTB.7
    IF PORTB.3=0 then
        LOW PORTB.7
    goto start
    How do you have the TRIS set for this?
    TRIS Series I have not configured but the code does not work well.
    You will need to set the TRIS for the port. That will tell what pins are input or out puts.
    Try adding this near the top of your code.
    TRISB = %00001111
    That will make PORTB 0 to 3 an input and 4 to 7 an output.
    Hello mackrackit,
    I have added TRISB =% 00001111 but as usual the code does not work well.
    Leonardo
    TRISB = %00001111
    Can you post the whole code and exactly what is it doing or not doing?
  1. Run a string of LEDs from the mains
    Last Post: - 1st October 2009, 19:55
  2. Replies: 14
    Last Post: - 26th April 2007, 16:12
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  4. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 22:02
  5. Replies: 5
    Last Post: - 16th February 2005, 12:57
