RT Config issue
Results 1 to 3 of 3
Thread: RT Config issue
    Sep 2005
    Campbell, CA
    Default RT Config issue
    I have been successfully using DT's RTCONFIG with an offset,
    For example
    @ ReadConfig?CB _CONFIG1H, _OSCTYPE
    But when I try to use the line
    @ ReadConfig?BB 200000h, _User1
    I get the error message
    "Register in operand not in bank0. Ensure that bank bits are correct."
    Can someone tell me what I'm doing wrong?
    Charles Linquist
    HI Charles,
    The @ ReadConfig?BB macro uses a BYTE variable as an offset from 300000h (CONFIG space). It can't read the ID locations (200000).
    You can read them with the ?CB macro ...
    @ ReadConfig?CB 200000h, _User1
        --OR--
    @ ReadConfig?CB _IDLOC0, _User1
    Or you could add this macro to the RTconfig include, which will let you use an offset from the first ID loc...
    ReadID?BB  macro  Breg, Bout
            movlw    upper(_IDLOC0)
            movwf    TBLPTRU, A
            movlw    high(_IDLOC0)
            movwf    TBLPTRH, A
            movff    Breg, TBLPTRL
            TBLRD*                            ; read the ID byte
            movff    TABLAT, Bout
    Then you could ...
    FOR X = 7 to 0 STEP -1
        @ ReadID?BB  _X, _User1
        LCDOUT HEX2 User1
    NEXT X
    Sep 2005
    Campbell, CA
    Thanks!
    I should have looked at your code for the answer, but it is month-end around here and I don't even have time to do anything constructive!
    Charles Linquist
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
