Fan regulator - Any advise
Results 1 to 11 of 11
    Question Fan regulator - Any advise
    Hello Everyone
    This is my first post here and hope to get some help from someone. I recently bought PICBasic Pro and tried few programs and now I feel it is time to jump into something more useful and exciting.
    I want to make a fan regulator using two rf modules and my PIC12f629. I found the following code on the net posted by someone, I can understand some of it but need some help to understand it completely:
    DEVICE 12F629
    CONFIG INTRC_OSC_NOCLKOUT, WDT_OFF, PWRTE_ON, BODEN_OFF, CP_OFF, MCLRE_OFF
    ;XTAL 4
    ALL_DIGITAL = TRUE
    ; 76543210
    TRISIO = %00011100 ;1-input, 0-output
    PORTB_PULLUPS OFF
    CMCON = 7 ;comparator off
    ;pull-up initialization
    ;OPTION_REG.7 = 0 ;enable pull-ups
    ;WPU.4 = 1 ;pull-up on GPIO.4 pin
    OPTION_REG = %11010101 ;presc 1:64 ,External Interrupt Edge to rising edge
    ;I/O symbols
    SYMBOL Triac_out = GPIO.0 ;pin for fiering triac
    SYMBOL IR_Receiver = GPIO.3 ;pin for receiving ir-data from ir-module
    SYMBOL Zero_cross = GPIO.2 ;pin for detecting zero-cross point
    SYMBOL Dim_UP_Button = GPIO.4
    SYMBOL Dim_DOWN_Button = GPIO.5
    ;interrupt symbols
    SYMBOL GIE = INTCON.7 ; Global Interrupt Enable 1 = enable, 0 = disable
    SYMBOL T0IE = INTCON.5 ;TMR0 Overflow Interrupt Enable bit
    SYMBOL INTE = INTCON.4 ;GP2/INT External Interrupt Enable 1 = enable, 0 = disable
    SYMBOL T0IF = INTCON.2 ;TMR0 Overflow Interrupt Flag bit
    SYMBOL INTF = INTCON.1 ;External Interrupt Flage 1 = external interrupt occurred (must be cleared in software)
    DIM Load_Value AS WORD
    DIM I AS BYTE
    ;Clear interrupt sources flages and enable them
    T0IF = 0 ;Clear TMR0 overflaw interrupt flag
    INTF = 0 ;Clear External Interrupt Flag
    ;T0IE = 1 ;Enable TMR0 overflaw interrupt
    ;INTE = 1 ;Enable External Interrupt
    ;GIE = 1 ;Enable Global interrupt ( 0 disable)
    Load_Value = 155
    ON_INTERRUPT Interrupt_Detect
    GOTO MAIN
    Interrupt_Detect:
    IF INTF = 1 THEN
    TMR0 = Load_Value
    T0IE = 1
    INTF = 0 ;Clear INT Flag (be ready for the next)
    IF T0IF = 1 THEN
    Bsf GPIO,0
    Nop
    Nop
    Nop
    Nop
    Nop
    Nop
    Nop
    Nop
    Nop
    Nop
    Bcf GPIO,0
    T0IF = 0
    CONTEXT RESTORE
    MAIN:
    GIE = 0 ' Turn off global interrupts
    While GIE = 1:GIE = 0:Wend ' Make sure they are off
    ;T0IE = 1 ' Enable TMR0 overflow interrupt
    INTE = 1
    GIE = 1 ' Enable global interrupts
    IF Dim_UP_Button = 1 THEN GOSUB DIM_UP
    IF Dim_DOWN_Button = 1 THEN GOSUB DIM_DOWN
    GOTO Main
    DIM_UP:
    Load_Value = Load_Value + 8
    IF Load_Value >= 155 THEN Load_Value = 155
    FOR I = 0 TO 5000 : DELAYUS 100 : NEXT
    DIM_DOWN:
    Load_Value = Load_Value - 8
    IF Load_Value <= 67 THEN Load_Value = 67
    Just to put some light on the above program, I want to add that this code was written in some proton (to me it looks very similar to PBP). It is meant to be an IR operated unit ( I will try RF modules).
    I just need some help on understanding timers & their role in above program along with the role of Load_Value as I dont understand the following as well in the code:
    " Load_Value = Load_Value - 8
    IF Load_Value <= 67 THEN Load_Value = 67" & also
    "Load_Value = Load_Value + 8
    IF Load_Value >= 155 THEN Load_Value = 155"
    Many Thanks
    Bombay, India
    Hey Now-started
    First of all, this code is very similar to what you can use in PBPro.
    Now to your specific queries.
    what the code is supposed to do is
    1. Get triggered by the external interrupt pin on a mains zero crossing
    2. When this happens, the TMR0 timer is loaded with the delay time to fire the triac. Think of this as a phase lag triggering like the triac dimmer you use in your lamps.
    3. The 67 and 155 are limiting values for the delay time, so when you increase the value it should not increase beyond 155 and when you decrease it should not go below 67. If these conditions are not met, you will have weird behaviour on the triac dimmer
    4. The load_value is the delay time I talk of here. The +/-8 is the step for the dimmer value
    I hope my explanation will turn on more light bulbs for you
    Hope you can put a name on your alias Now_started
    Lightbulb
    Hi, Jerson
    Talking about lamps ...
    I don't know if this circuit can work with LITTLE fans motors ... ( synchronous motors or computer fans ... between others ... )
    Smile
    Thanks Jason, my name is Damien. Your explanation has showed me light at the end of a looong tunnel. Few questions have risen again:
    1) Does this code wait for any command to start the light/fan or as soon as the circuit is connected it fires the triac?
    2) What is "Nop, Nop..." & why it is repeated many times?
    Thanks again (Getting there)
    Bombay, India
    Hi Damien
    The code starts right away. It uses the DIM_UP and DIM_DOWN buttons to change the dimming value.
    the NOP commands are repeated as a means of attaining a small delay time between the GPIO.0 on and GPIO.0 off commands. Meaning, make a tiny pulse to fire the triac.
    A tiny warning, the PBPro compiler doesn't support the CONTEXT RESTORE command. You should also read up on Darrel Taylor's instant interrupts to get this working smoothly under PBPro. The interrupts supported by PBPro are too primitive to achieve anything time critical.
    Alain, I think the circuit should be good for a ceiling fan too. The triac rating should help to decide that.
    Smile
    [QUOTE=Jerson;77773]
    [QUOTE]
    Thanks Jerson (sorry to call you Jason before), where can I read about Darrel Taylor's instant interrupts? & can you advise me of what will be the replacement code for CONTEXT RESTORE (what does it do?))
    P.S: I know that it may be too much to ask, but can someone please make important corrections to this code according to PBPro, I think I will be able to adjust the rest according to my need (atleast I hope)
    Wink KISS Method
    Looking at this interrupt stubb ... it seems translating it into pure ASM interrupt is fairly easy ... as all commands have their straight asm equivalent !!!
    BTW ... I do not see DT Interrupts fitting into a '629 ...
    Smile PIC Option
    I have 12F635 as well, if that helps
    Bombay, India
    Am I missing something? I looked up microchip site for 16F629 ... nothing. Is it a 639 and a 635 you talk about?
    As to whether DT instant interrupts fits in a 628 or equivalent, I'm not sure, but I've used assembly language interrupts on a 628. It's very easy once you know.
    Talking
    Hi, Jerson
    You should have a strong coffee ...
    DEVICE 12F629
    lol ...
    For DT interrupts ... the problem is the RAM size, not the Program size ...
    So, a 12Fxxx with enough RAM ( 12F683 i.e. ) is Ok
    It won't fit into a 16F84 nor ...
    Bombay, India
    Hi Alain - I really needed coffee. Too much stress I guess. I mistook it for a 16F device!!! haha
    OTOH 64 bytes RAM should be good enough to do asm interrupts no?
    This is what I did with the 16F628 interrupts.
    ' define the interrupt handler
    define      INTHAND       _IntHandler
    ' These variables are used to save the machine state on interrupt
    wsave       var byte    $20     SYSTEM          ' location for W if in bank0
    wsave1      var byte    $A0     SYSTEM          ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM          ' location for W if in bank2
    ssave       var byte    BANK0   SYSTEM          ' location for STATUS register
    psave       var byte    BANK0   SYSTEM          ' location for PCLATH register
    fsave       var byte    BANK0   SYSTEM          ' location for FSR register
    IntHandler:
    asm
          movwf   wsave           ; Save the W register
          swapf   STATUS, W
          clrf    STATUS          ; Point to bank 0
          movwf   ssave           ; Save the STATUS register
          movf    PCLATH, W       ; Save PCLATH
          movwf   psave
          movlw   ((INTHAND) >> 8)        ; Set PCLATH for jump
          movwf   PCLATH
          btfss INTCON, INTF    ; branch if PULSEIN arrived
          goto  EndInt
    ; your code goes here
          ; restore the machine context
    EndInt
          movf  fsave,w         ;restore the FSR
          movwf FSR
          movf  psave,w         ;restore PCH
          movwf PCLATH
          swapf ssave, W        ;restore STATUS
          movwf STATUS
          swapf wsave, F
          swapf wsave, W        ;restore W
          retfie
    endasm
    I have not checked the datasheet for the banks used in the 12F629, but the wsave registers may need to change accordingly. Otherwise, the context save and restore takes just 4 bytes of RAM !!!!
    That also answers Damien as to the code needed for the CONTEXT RESTORE of proton
  1. Proportional fan control. I suck at math!
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 4th January 2010, 00:10
  2. 12f635 & fan regulator
    Last Post: - 24th August 2009, 23:10
  3. Transistor selection, PWM fan control
    By 124C41 in forum Schematics
    Last Post: - 22nd December 2008, 16:33
  4. help with fan controller X10
    By iova in forum General
    Last Post: - 11th August 2006, 01:37
  5. Replies: 9
    Last Post: - 30th August 2005, 07:33
