PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
Results 1 to 38 of 38
    The encoder outputs channels which has a 90° phase shift between them.
    The QEI-module can be set to 2X or 4X mode (X4 is the most common) but the easiest to understand is the 1X mode....
    Simply, if the B channel is high on the rising edge of the A channel then you count up, if the B channel is low on the rising edge of the A channel then you count down. In 2X mode you "trig" on the rising edge of both channels (giving you a resolution of 2X the line count of the encoder) and it 4X mode you trig on the rising AND falling edge of BOTH channels (giving you a resolution of 4X the line count of the encoder).
    If you look up incremental or quadrature encoder on Wikipedia you'll find more details.
    Thanks Henrik,
    I understand now.
    May 2007
    Republic Serbia
    Unhappy New question is start for next stage of project
    Now I am probe on many ways to do next but I cant to image how.
    1. I was setup count for QEI with friends from these forum to count from 0 - 12500 - becous my motor have gear 6.25:1 and 6.25*2000 = 12500(reding of one turn of motor shaft with 500 lines encoder) give me full 360' of output shaft range.That work extra.
    Next : If I want to move for example 1mm on my mechanic I need one turn of output shaft that give me easi to control position of count from CW 0-12500 or CCW 12500 to 0.That is all in 16bit counter.
    But what if I need to move more then 16bit counter ?
    OK I can use PBPL and define 32bit variable - I was probe and it work 100%.
    I can easy set to se if X VAR LONG number 25000000 that give me 25000000/12500 = 2000mm - inpresive!
    But how I can my software variable defined as LONG from 0 - 25000000 to increment or decrement from hardware COUNT buffer wich count in circle from 0-12500 and vice verse ?
    Is any idea becouse all what I was probe give me garbage of result.
    Regards Robert
    May 2007
    Republic Serbia
    Unhappy
    OK now next step are steped.
    I write calculation to increment in CW my variable defined as LONG to be incremented from position buffer
    which go from 0-12500 and again and again..
    ' Pic 18F4431 @ 20MHz true XTAL
        define osc 20
        DEFINE HSER_RCSTA 90h
        DEFINE HSER_TXSTA 24h
        DEFINE HSER_SPBRG 64
        DEFINE HSER_CLROERR 1
        ADCON0=0
        ANSEL0=0
        PortA = 0
        PortB = 0
        PortC = 0
        TRISA = %011100
        TRISB = %00000000
        TRISC = %10000000
        QEICON=%10011000
        DFLTCON = %00111000
        MAXCNTL = %11010100
        MAXCNTH = %00110000
        PosLow VAR BYTE
        PosHigh VAR BYTE
        PosTemp VAR BYTE
        Position VAR WORD
        y var LONG
        x var BYTE
        x = 0
        y = 0
        POSCNTL = 0
        POSCNTH = 0
        PIR3.2 = 0
        CLEAR
        Start:
        Gosub GetPosition
        y =  (x * 12500) + position
        HSEROUT [dec y]
        Pause 10
        Goto Start
    GetPosition:
        PosHigh = POSCNTH
        PosLow = POSCNTL
        PosTemp = POSCNTL
        If PosLow - PosTemp = 0 then Goto Done
        PosHigh = POSCNTH
        PosLow = POSCNTL
    Done:
        Position = POSHIGH * 256 + PosLow
        if PIR3.2 = 1 then x = x+ 1
        PIR3.2 = 0
    Now I can count a long trip of mechanic of machine which is present in LONG variable in CW direction.
    But I have new problem in my head all these days and it is next.
    I have BIT which indicate direction of motor and it is in QEICON.5.
    If QEICON.5 is 0 then we go CCW and if it is 1 then we go CW direction.
    Now if we go CW and stop motor it wil be 1 all the time to next move
    and if we go CCW it will be 0 and after we stop from CCW it will be 0 all time to next move..
    Confuse how to make matematic to implement new formula for decrement LONG variable in CCW :
    y = y - (12500-position) or similar becous in CCW position go from 12500-0 and again 12500-0....
    If any idea or someone want to help THANKS.
    Regards Robert
    Maybe I am missing something but if you stop the motor and then restart it you know the direction?? Set the direction bit when you start the motor.
    May 2007
    Republic Serbia
    Here is code which can measure and put to Y variable defined as LONG position of mechanic on machine to 32bit and count up and down.
    I am not good programmer but code work good.
        define osc 20
        DEFINE HSER_RCSTA 90h              ' Enable serial port & continuous receive
        DEFINE HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
        DEFINE HSER_SPBRG 64               ' 19200 Baud @ 20MHz, 0.16%
        DEFINE HSER_CLROERR 1              ' Clear overflow automatically
        ADCON0=0                           'Turn of ADC
        ANSEL0=0                           'Make Port A inputs Digital
        PortA = 0
        PortB = 0
        PortC = 0
        TRISA = %011100                    'QEI pins as inputs.
        TRISB = %00000000
        TRISC = %10000000                  'USART RX pin as input.
        QEICON=%10011000
        DFLTCON = %00111000                ' enable error filter for all capture inputs
        MAXCNTL = %11010100                'low set for maxcnt of 12500 becouse have gear 6.25:1
        MAXCNTH = %00110000                'hig set for maxcnt of 12500 becouse have gear 6.25:1
        'MAXCNTL = %00000001               'lowbyte = 207
        'MAXCNTH = %00000000               'highbyte = 7 but after math: highbyte * 256 = 1792 + 207 = 1999
        'QEICON = %00010100                'Setup QEI, 4X mode, reset on index.
        PosLow VAR BYTE                    'Storage for the low byte of encoder count
        PosHigh VAR BYTE                   'Storage for the high byte of encoder count
        PosTemp VAR BYTE                   'Temporary storage for low byte of encder count
        Position VAR WORD                  'Actual encoder position, 16bit word.
        y var long                         'Total pulse count storage variable 32bit
        x var byte                         'Number of full shaft rotation of 360'
        z var BIT                          'Actual bit if any move of shaft to any direction
        h var BIT                          'direction bit 0 for left , 1 for right turn of encoder
        z = 0
        x = 0
        y = 0
        h = 0
        POSCNTL = 0                        ' clear lowbyte of counter for start
        POSCNTH = 0                        ' clear highbyte of counter for start
        PIR3.2 = 0
        CLEAR
        Start:
        Gosub GetPosition
        y =  (12500 * x) + position                    ' increment  total counter
        if z = 1 and h = 0 then y = y-(12500-position) ' dectement  total counter
        HSEROUT [DEC y]                                 ' debug via rs232 @ 19200
        Pause 100                                       'Wait....
        Goto Start                                     '...and do it again.
    GetPosition:
        z = 0
        PosHigh = POSCNTH                           'Get high byte of counter
        PosLow = POSCNTL                            'Get low byte of counter
        PosTemp = POSCNTL                           'Get low byte again
        If PosLow - PosTemp = 0 then Goto Done      'Compare, if equal we're done.
        PosHigh = POSCNTH                           'If not, get values again.
        PosLow = POSCNTL
        z = 1
    Done:
        Position = POSHIGH * 256 + PosLow           'Put high and lowbyte together.
        h = QEICON.5                                'QEICON.5 for right = 1 for left = 0
        if PIR3.2 = 1 and h =1 then x = x+ 1
        if x <> 0 and PIR3.2 = 1 and h =0 then x = x- 1
        PIR3.2 = 0                                  'PIR3.2 maxcount transition down or up was detected
        h = 0
    Quote Originally Posted by phoenix_1 View Post
    What is a good programmer???
    If it works as you want then it is good.
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 14:45
  2. Best quadrature encoder for buck?
    By jrprogrammer in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2009, 13:58
  3. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  4. saving RCREG to word
    Last Post: - 15th September 2008, 13:51
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
