Here is success probe with count encoder from 0 to 2000 for one turn of shaft of motor.
' Pic 18F4431 @ 20MHz true XTAL
    define osc 20
    DEFINE HSER_SPBRG 64  ' 19200 Baud @ 20MHz, 0.16%
    ADCON0=0 'Turn of ADC
    ANSEL0=0 'Make Port A inputs Digital
    PortA = 0
    PortB = 0
    PortC = 0
    TRISA = %011100                'QEI pins as inputs.
    TRISB = %00000000
    TRISC = %10000000              'USART RX pin as input.
    QEICON=%11001100
    DFLTCON = %00111000            ' enable error filter for all capture inputs
    MAXCNTL = %11001111           'lowbyte = 207
    MAXCNTH = %00000111           'highbyte = 7 but after math: highbyte * 256 = 1792 + 207 = 1999
'QEICON = %00010100                   'Setup QEI, 4X mode, reset on index.
    PosLow VAR BYTE                          'Storage for the low byte of encoder count
    PosHigh VAR BYTE                         'Storage for the high byte of encoder count
    PosTemp VAR BYTE                        'Temporary storage for low byte of encder count
    Position VAR WORD                      'Actual encoder position, 16bit word.
    POSCNTL = 0                            ' clear lowbyte of counter for start
    POSCNTH = 0                            ' clear highbyte of counter for start
CLEAR
    Gosub GetPosition
    HSEROUT [dec position]
    Pause 100
Goto Main
GetPosition:
'Since the position counter isn't double buffered we can get to situations
'where the lowbyte overflows between readings of the high and the low byte. This
'is prevented by reading the low byte two times and compare the two readings.
'If they are the same then we're fine, if not re-read the registers.
    PosHigh = POSCNTH                       'Get high byte of counter
    PosLow = POSCNTL                        'Get low byte of counter
    PosTemp = POSCNTL                       'Get low byte again
    If PosLow - PosTemp = 0 then Goto Done      'Compare, if equal we're done.
    PosHigh = POSCNTH                           'If not, get values again.
    PosLow = POSCNTL
Done:
    Position = POSHIGH * 256 + PosLow           'Put high and lowbyte together.
Will continue...
