Crude logrithms?
Results 1 to 3 of 3
    Omaha, Nebraska USA
    Question Crude logrithms?
    Does anyone know of a simple way to get crude/approximate logs? Or should I just put a lookup table in EEPROM?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    I've never used it, but it looks interesting.
    http://www.dattalo.com/technical/sof...ic/piclog.html
    <br>
    Miami, Florida USA
    There are many methods for approximating a logarithm but all require a lot of computation to get a decent approximation. If you can deal with continued fractions or powers to the fourth then you are fine.
    Another solution is to plot the log function that you will use in the range that you need using a program like Microsoft Excel. Then find an approximation (an equation) using the functions provided in the Excel program.
