I know the following is commented out, but not sure what is going on here:You want to make sure all the analog inputs (ADC and Comparators) are set to digital. Also I think your TRIS directives are backwards (i.e. desired output are inputs and viceversa). Again this is commented out, but you should be defining these things at the beginning.Code:'ADCON0 = %11000001 'ADCON1 = %10001110 'trisa = %00001110 'trisb = %11110111
Not sure what the real problem is, but somehow I think you are having a stack overflow.
Try replacing the "GOsub warning" with "GOto warning"; and "RETURN" with "GOto monitor".
