Tachometer with Interrupts
Results 1 to 15 of 15
    Lightbulb
    Use ASM interrupts ...
    NOT PBP Interrupts
    May 2008
    Italy
    If you oscillator is wired as per your diagram it will not work!
    Al.
    Oct 2008
    Quote Originally Posted by aratti View Post
    Al.
    I don't understand what you mean? Should I remove crystal on ISIS?
    Oct 2008
    NOT PBP Interrupts
    how to use ASM interrupts in PBP ?
    Dec 2008
    Ploiesti, ROMANIA
    Check this picture.
    Oct 2008
    Quote Originally Posted by fratello View Post
    Check this picture.
    I see, but Crystal has no effect on Simulation. I wired it now correctly, but it gives again different values.
    Oct 2008
    I tried also with the command count
    Count PortB.0,1000,Value, and it gives the correct value
    Some " real world " ideas ...
    http://www.usinages.com/compte-tours-t26.html
    Oct 2008
    I want to use this for my wind turbine...
    Quote Originally Posted by serkanc View Post
    Easiest way is use Darrel's Instant Interrupts
    Sep 2005
    Campbell, CA
    Tach input on any pin
    Uses Darrel Taylor's Instant Interrupts
    Fast, since is in ASM
    This routine uses TMR0, but will work with any other unused timer.
    To use -
    Set interrupt period so that there will ALWAYS be an interrupt in the shortest
    "high" or "low" period you want to measure. For example, if highest tach freq
    is 100Hz and is a square wave, the period will be 10msec and the "high" part
    of the square wave will be 5msec and the "low" period will be 5msec. In this case
    the interrupt period should be 5msec minimum - choose 4 msec or less (must be a
    little less than 5msec to cover interrupt latency). If the tach frequency is higher
    or the input is not a square wave, you will have to increase the interrupt rate
    accordingly.
    In your main PBP routine - Clear TachCounter,ShaftCounter1,ShaftCounter2,Shaftcount erX.
    Then clear PeriodDone. The routine will count for 1000 interrupts. When you want to
    read the tachs, check if PeriodDone bit 0 is set - if it is, then the count is finished.
    Move the ShaftCounters into PBP variables, Clear the shaftcounters and clear PeriodDone.
    The cycle repeats and runs totally in the background.
    You will have to mutliply the ShaftCounter variables by a value determined by
    the tachometer and interrupt rate to get actual RPM.
    The code can probably be improved, but it works for me.
    Asm
    ReadTachs
             movlw   0xEC              ; Reload TMR0 with your own value - sets INT rate - see explanation above
             movwf   TMR0H             ; Load the high byte first
             movlw   0x7E              ; Load the low byte
             movwf   TMR0L
             btfss   PeriodDone,0      ; Check to see if counting period is over
             bra     CheckTach
             bra     DoneForNow
             infsnz  TachCounter       ; 16 bit counter
             incf    TachCounter + 1
             movlw   0x03 - 1          ; 1000 = 0x3E8, but must have one less
             cpfsgt  TachCounter + 1   ; to compare with greater than (choose a different number if you like)
             bra     FanRoutine
             movlw   0xE8 - 1          ; Again, subtract one
             cpfsgt  FanCounter
             bra     MainRoutine
             bsf     PeriodDone,0      ; Set the PERIOD Done lsbit
             clrf    TachCounter       ; Clear the counter
             clrf    TachCounter+ 1
             bra     DoneForNow
    MainRoutine
             movf    PORTB,0,0         ; Load all of Port B
             movwf   Temp,0            ; Copy it into TEMP for safety
             xorwf   OldPortB,0,0      ; XOR it with previous read
             movwf   changedB,0        ; Move the XORed byte into variable
             movff   Temp,OldPortB     ; Move Temp to OldPortB
             movf    PORTC,0,0         ; Do the same for PORTC (or any port with a tach input)
             movwf   Temp,0
             xorwf   OldPortC,0,0
             movwf   changedC,0
             movff   Temp,OldPortC
             movf    PORTD,0,0
             movwf   Temp,0
             xorwf   OldPortD,0,0
             movwf   changedD,0
             movff   Temp,OldPortD
    Shaft1
             btfss   changedB,0       ; Read in the bit - if it changed from last read it will be a "1"
             bra     Shaft2           ; It hasn't changed, so go to next
             infsnz  Shaft1Counter    ; Increment the counter lowbyte
             incf    Shaft1Counter+1  ; If necessary, increment the high byte
    Shaft2
             btfss   changedC,1       ; This shaft tach is fed into PORTC.1
             bra     Shaft3
             infsnz  Shaft2Counter
             incf    Shaft2Counter+1
            ; Put more shaftcounters here if you need them.
    DoneForNow
             bcf     INTCON,2           ; Clear the TIMER0 interrupt flag
           INT_RETURN
    Charles Linquist
    Oct 2008
    Thanks for help.. I tried to write codes with CCS C, it's very simple.. Asm codes are difficult for me.. So it works without any problem. If someone needs I can paste the codes..
    Sep 2006
    Please paste the code,would love to see.. Regards.
    Oct 2008
    #include <16F628A.h>
    #FUSES NOWDT //No Watch Dog Timer
    #FUSES HS //High speed Osc (> 4mhz for PCM/PCH) #FUSES NOPUT //No Power Up Timer
    #FUSES NOPROTECT //Code not protected from reading
    #FUSES NOBROWNOUT //No brownout reset
    #FUSES MCLR //Master Clear pin enabled
    #FUSES NOLVP //No low voltage prgming, B3(PIC16) or
    #FUSES NOCPD //No EE protection
    #use delay(clock=4000000)
    #define LCD_DATA_PORT getenv("SFR:PORTB")
    #define LCD_ENABLE_PIN PIN_A1
    #define LCD_RS_PIN PIN_A0
    #define LCD_RW_PIN PIN_A2
    #define LCD_DATA0 PIN_B4
    #define LCD_DATA1 PIN_B5
    #define LCD_DATA2 PIN_B6
    #define LCD_DATA3 PIN_B7
    #define LCD_TYPE 2
    #include <lcd.c>
    long suretmp;
    long sure;
    #int_EXT
    void EXT_isr(void)
    suretmp=sure;
    sure=0;
    set_timer0(0);
    #int_TIMER2
    void TIMER2_isr(void)
    sure++;
    void main()
    long devir;
    int i;
    setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
    setup_timer_1(T1_DISABLED);
    setup_timer_2(T2_DIV_BY_1,99,1);
    setup_comparator(NC_NC_NC_NC);
    setup_vref(FALSE);
    setup_oscillator( OSC_4MHZ );
    lcd_init();
    enable_interrupts(INT_EXT);
    enable_interrupts(INT_TIMER2);
    enable_interrupts(GLOBAL);
    while(1)
    for(i=0;i<250;i++)
    delay_us(2);
    lcd_gotoxy(1,1);
    devir=600000/suretmp;
    if((600000%suretmp)>(suretmp/2))
    devir++;
    printf(lcd_putc,"%Lu mS Passed",suretmp);
    printf(lcd_putc,"\n%Lu RPM",devir);
  1. Continuous Interrupts when using DT_INTS and an INCLUDE file
    Last Post: - 15th January 2010, 22:42
  2. Tachometer with DT Interrupts?
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 17th November 2009, 20:51
  3. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
