bad expression error, linking addresses incorrectly.
Results 1 to 6 of 6
    Aug 2009
    Default bad expression error, linking addresses incorrectly.
    hi sorry again but i can't seem to work out what im doing wrong, its gonna be a very simple answer but i cant see it.
    im using a 18f2431, im trying to link the addresses of my temporarily saved data in the buffers, to be used in a calculation, and then that "answer" to be linked to be put as the duty in the hpwm output.
    sorry im a rookie but im tryin to learn
    this is my code:
    DEFINE OSC 20
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true
    T1 VAR WORD
    T2 var word
    T3 var word
    Capture1 VAR PIR3.1
    Capture2 var pir3.2
    Capture3 var pir3.3
    False CON 0
    True CON 1
    ' auto time base reset, frequency mode, capture on every rising edge
    period1 CON %01000101
    period2 CON %01000101
    period3 CON %01000101
    ANSEL0=0 ' All digital
    TRISA.2 = 1 ' this is your (CAP1) input pin measuring the frequency
    TRISA.3 = 1
    TRISA.4 = 1
    INTCON = 0 ' Interrupts off
    TMR5H = 0 ' Clear high byte of TMR5 counter
    TMR5L = 0 ' Clear low byte
    T5CON = %00000001 ' prescale=1:1, int clock, TMR5=on
    CAP1CON = period1 ' we're measuring a period
    CAP2CON = period2
    CAP3CON = period3
    Capture = False ' Reset capture flag
    GOSUB pulsewidth ' get pulsewidth
    ' At 20MHz, to figure a PWM frequency of 19.455kHz
    ' TPWM = time period of PWM frequency
    ' PTPER = 12-bit period register PTPERL and PTPERH
    ' PTMRPS = PWM time base prescaler
    ' (PTPER+1)*PTMRPS 257
    ' TPWM = ---------------- = ------------ = 0.0000514
    ' Fosc/4 5000000
    ' Frequency = 1/TPWM = 1/0.0000514 = 19.455kHz
    ' PWM resolution (bits resolution for duty cycle)
    ' log(20MHz/19.455kHz) 3.01
    ' Resolution = ------------------ = ----------- = 10 bits
    ' .301 .301
    ' so we'll need a word sized var for Duty
    Duty Var Word
    PORTB = 0 ' clear port latch
    TRISB = %11000000 ' PWM0,1,2,3,4,5 outputs
    TRISC = 2 ' RC1 = FLTA input (ground RC1 to halt PWM)
    ' RC1 should be pulled high for normal PWM operation
    ' when fault A is enabled.
    ' PCPWM init
    PTCON0 = %00000000 ' 1:1 postscale, Fosc/4 1:1 prescale, free running mode
    ' PTCON0 = %00000100 would give 19.45kHz/4
    PTPERL = 0 '
    PTPERH = 1 ' PTPER = $0100 or 256d for ~19.45kHz
    ' PWM4,5 independent
    PWMCON0 = %01010100 ' PWM[5:0] outputs enabled
    PWMCON1 = 1 ' updates enabled, overrides sync w/timebase
    PTCON1 = %10000000 ' PWM time base is ON, counts up
    FLTCONFIG = %00000011 ' enable fault A, cycle-by-cycle mode
    Duty = dutycycle ' ~50% however this will be changed in respect to algorithm
    PDC2L = Duty.LowByte ' maintain a duty cycle on PWM4,5
    PDC2H = Duty.HighByte ' independent PWM outputs.
    PAUSE 5
    GOTO Main
    pulsewidth:
    ' Frequency measurement mode, capture Timer5 count every rising edge
    ' with auto reset of Timer5 on each event
    WHILE Capture = False
    WEND
    T1.HighByte = CAP1BUFH
    T1.LowByte = CAP1BUFL
    T2.HighByte = CAP2BUFH
    T2.LowByte = CAP2BUFL
    T3.HighByte = CAP3BUFH
    T3.LowByte = CAP3BUFL
    F69H VAR BYTE 'Value of period at CAP1 ready for calculation, f69h being its address from data sheet
    F67H VAR BYTE 'Value of period at CAP2 ready for calculation
    F65H VAR BYTE 'Value of period at CAP3 ready for calculation
    ''''''''''''''''''''''''''''''''''''Algorithm for finding power''''''''''''''''''''''''
    averageperiod var byte 'saving average period to ram
    averageperiod = (F69H+F67H+F65H)/3 'average period found using 3 periods
    'for now im using arbitary random scaling factors, until i have the actual graphs to get the real rpm against power
    rpmvalue var byte 'saving rpm value to ram
    rpmvalue=60/(8*averageperiod) 'finding rpm value using current period measurement
    power var byte 'saving power to ram
    IF rpmvalue<=300 Then
    power=rpmvalue/15
    power=rpmvalue/10
    ' now i need to link power to the arbitary pwm output
    'this is a standard quadratic function (quadratic in example case anyway)
    dutycycle var byte 'byte being the one that is answer of algorithm when thats created
    dutycycle = (power^2)+(5*power)+3 'finding dutycycle using rpmvalue
    sorry it was alot neater than that in microcode studio...
    Aug 2009
    also when i try and look at some of the threads that rorchach, or whatever his name is has posted in my antivirus keeps stopping me... i keep getting attacked by a trojan horse in those threads... not sure if anyone else has got this? but it keeps happening to me only on those recent threads.
    Those threads and the Spammer have been killed.
    Aug 2009
    ok doesnt look like anyone could help me before.. but i have a new question regarding the 2431.
    ive been trying to get a pwm output using the following code:
    Duty Var Word
    ' PCPWM init
    DTCON = %00000101 ' ~500nS dead-time (for complementary outputs only)
    PTPERL = 0 '
    ' PWM4,5 independent, PWM0,1,2,3 complementary
    Duty = 800 ' ~50%
    PDC2L = Duty.LowByte ' maintain a fixed 50% duty cycle on PWM4,5
    last night this code worked for me, and i was getting a good pwm output. however today it wont work, ive checked my wiring is correct, by testing using multimeter and with other programs. however when i run the current program i get a pulse width output for about 10 seconds before it dies, i also havee an led attached to one of the pwm outputs which also fades out at the same time to check. ive fiddled alot with the fault byte to check it wasnt that. but i cant think of what else could be causing this problem? also for the 10 seconds it does appear... the 0 points on my pwm wave are actually slanted upwards slightly...?
    additionally since i havnt purchased a crystal yet, i thought id use the internal oscilattor INTIO1. this runs at a maximum of 8mhz. maybe this is causing the problem? ive tried to adjust my prescalers inrespect to this, however i still get the problems.
    Aug 2009
    oh and sometimes (moreso now) i dont get a pwm at all... it just makes the led (thats linked to a pwm output) turn on for about 10 seconds and then fade out and nothing more.
    Aug 2009
    ok ignore that one... took me a while (two days almost) to figure out where i went wrong on that one...
    but i still am having trouble with using values that are from a specific buffer, and using them in calculations etc... do i need to use there addresses? or just the buffer name? etc
  1. PBP bad expression
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 24th October 2009, 02:01
