SEROUT Just Garbage!
Results 1 to 37 of 37
    Sep 2005
    Campbell, CA
    Since the level converter provides inversion, and it works with the level converter, it follows that if you are not using a level converter, you need to send the data inverted.
    Charles Linquist
    SWITZERLAND (french speaking)
    I just can't find the setting to "invert" data on Hyperterminal for Windows XP. Same for the Terminal emulator within Micro Code Studio.
    Since I'm always getting these same bizarre characters, it might effectively be because of this missing signal invertion.
    Can someone suggest any terminal emulator I could use?
    Roger
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by flotulopex
    I use Tera Term. I find it much easier to use than hyperterminal. But, and I am speaking in the blind a little hear, I don't know if you can invert the singnals from the terminal software. Either way, you may find you like Tera Term, and it's FREE!
    Sep 2005
    Campbell, CA
    I'm not talking about inverting the data on your terminal.
    You have to do it in the PIC. There are two options on SEROUT - one TRUE and one INVERTED. Use the INVERTED option.
    Charles Linquist
    Looking at the code I was given I see
    tx_pin = 0 'inverted mode idle state
    Could maybe try that on RX_pin...
    Are you trying the code and chip I was given?
    I'm using both hyper term and micro code one both work fine with formal settings and im using xp.
    Well,
    It took me a while to find out how to calculate the correct "mode" value for the SEROUT2 command. Finally, it works well (on both PICs 12F675 and 16F88).
    I still don't understand the difference between the SEROUT and the SEROUT2 commands. I read the Micro Code Studio's help files but they are not very clear to me. Or is it only that SEROUT handles "only" 8 bits and SEROUT2 can handle up to 9 bits?
    My previous post sounds now a little stupid but what can be crystal clear for you can be foggy to me... Thank you for your patience.
    Roger
    Glad you got it working
    I am very new to all this as well so I don't understand a lot either... The important thing tho is you have it working and now know how to get another working
    Daniel
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
