SEROUT Just Garbage!
Results 1 to 37 of 37
    Oh lol yea guess that wouldn't work well thanks... hmm How do you send to serial port on a different serial pin? Now I understand the problem im confused on how to fix it lol.
    I seem to have a lot of "Only learning opportunities." but atleast im learning
    how about something like
    '12F675
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    DEFINE OSCCAL_1K 1
    INCLUDE "modedefs.bas"
    TX_Pin var GPIO.0    'To DB9 RX pin 2
    RX_Pin var GPIO.1    'To DB9 TX pin 3
    TRISIO.0 = 0         'Set GPIO.0 to output.
    TRISIO.1 = 1         'Set GPIO.1 to input
    ANSEL = 0            'disable ADCs
    CMCON = 7            'disable comparator
    AChar var byte
    tx_pin = 0           'inverted mode idle state
    achar="A"
    Pause 100            'OSC settle time...
    loop:
        SerOut tx_pin,N2400,["Waiting for ",achar,13,10]
        SERIN  rx_pin,N2400,[achar]
        serout tx_pin,N2400,["Got it...",13,10]
        goto loop
    Thank you very much Mister_e that works perfect and will get me a good start on serial
    Its so great to have cool people around that help us noobs
    Talking
    You're welcome. Great to hear it help you.
    Have fun!
    Mister_e Mind if I email you or ask a non related question here?
    No problem.
    SWITZERLAND (french speaking)
    geckogrotto,
    I'm actually trying to understand a little bit more about serial communication and making some tests on my side too.
    I had to use a level converter (MAX232) to make the communication work.
    Looking at some posts, I have understand you connected your PIC directly to the PC's serial port (= without converter)?
    I must be wrong, no?
    Roger
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
