SEROUT Just Garbage!
Results 1 to 37 of 37
    I Think your Oscal might be off or Lost!
    Try this code below to see.
    'Lost oscal recover program
    ' Use Hyper_Term settings "9600 N,8,1"
    @ DEVICE pic12F675
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    @ DEVICE pic12F675, WDT_OFF
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, CPD_OFF
    @ DEVICE pic12F675, BOD_OFF
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, PROTECT_OFF
    SO VAR GPIO.0 ' serial out pin
    ANSEL = 0 ' disable converters
    CMCON = 7 ' disable comparators
    OSCCAL = 0 ' starting value
    Pause 2000
    loop:
    OSCCAL = OSCCAL + $10 ' increment calibration value
    SerOut2 SO,16468,[HEX2 OSCCAL, " This is a close OSC Value!",10,13] ' Display the hex value
    Pause 750 ' give time to read the value
    GoTo loop ' do it forever
    Ok I had to make a chane to get it to compile mine doesn't like how you did the defines but here it is
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _CP_OFF & _CPD_OFF
    Pause 2000
    loop:
    I setup hyperterm with the settings you said and then set it to vt100 as well? its running now will let you know how it does.
    Also I should be using pin 2 on serial as the input? and pin 5 to ground?
    The Gpio.0 ---->1k resistor---->pin 2 on a DB9 "rxpin" --->computer
    Ok cool I left it running for a while and got
    80
    90
    A0
    B0
    all close so how do I program that into the chip?
    I mean permanitly because I think I lost it on a number of chips when I very first started.
    Using Pic Kit 1 I don't see a way to manually set it.
    Also could I get a sample of using SERIN?
    I have tried this and it outputs the hello world and then waits there and never loops. So I can only assume that its not getting the "A" char when I try and send it.
    InputSig var GPIO.0
    loop:
    SerOut Inputsig,N2400,["Hello World",13,10]
    Serin InputSig,N2400,["A"]
    Pause 200
    GoTo loop
    SerOut Inputsig............
    Serin InputSig............
    must be a copy/paste error...
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
