SEROUT Just Garbage!
Results 1 to 37 of 37
    Set up "Hyper term" using "VT100 Emulation".
    Then set the comm port like this
    Bits per sec = 2400
    Data bits =8
    Parity = none
    Stops bits = 1
    Flow control = none
    Tried that but still nothing
    Can you post youre code!
    I thought that was you that asked me for it. I emailed it to someone.
    Here it is I had added a led to it just to make sure the chip was actually working but here it is.
    '12F675
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    TRISIO.0 = 0   'Set GPIO.0 to output.
    ANSEL.0 = 0    'Set GPIO.0 to digital
    GPIO.0 = 0
    CMCON = 7 ' PortA Digital inputs
    VRCON = 0        ' Voltage reference disabled
    OPTION_REG.7 =    0
    DEFINE OSCCAL_1K 1
    INCLUDE "modedefs.bas"
    led2 var GPIO.1
    loop:
    SerOut GPIO.0,N2400,["Hello World"]
    Pause 1000
    SerOut GPIO.0,N2400,["abc",13,10]
    Pause 4000
    high LED2
    LOW LED2
    high LED2
    LOW LED2
    GoTo loop
    I Think your Oscal might be off or Lost!
    Try this code below to see.
    'Lost oscal recover program
    ' Use Hyper_Term settings "9600 N,8,1"
    @ DEVICE pic12F675
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    @ DEVICE pic12F675, WDT_OFF
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, CPD_OFF
    @ DEVICE pic12F675, BOD_OFF
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, PROTECT_OFF
    SO VAR GPIO.0 ' serial out pin
    ANSEL = 0 ' disable converters
    CMCON = 7 ' disable comparators
    OSCCAL = 0 ' starting value
    Pause 2000
    loop:
    OSCCAL = OSCCAL + $10 ' increment calibration value
    SerOut2 SO,16468,[HEX2 OSCCAL, " This is a close OSC Value!",10,13] ' Display the hex value
    Pause 750 ' give time to read the value
    GoTo loop ' do it forever
    Ok I had to make a chane to get it to compile mine doesn't like how you did the defines but here it is
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _CP_OFF & _CPD_OFF
    Pause 2000
    loop:
    I setup hyperterm with the settings you said and then set it to vt100 as well? its running now will let you know how it does.
    Also I should be using pin 2 on serial as the input? and pin 5 to ground?
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
    Last Post: - 13th December 2008, 17:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 04:26
  5. Replies: 11
    Last Post: - 13th July 2005, 19:26
