LCD contrast
Results 1 to 4 of 4
Thread: LCD contrast
    Default LCD contrast
    If a LCD is 4 lines by 20 characters and we turn the contrast way up, do we get:
    - 1 line contrast squares, 1 line blank, 1 line contrast squares, 1 line blank.
    or
    - 4 lines contrast squares.
    It looks like I'm as successful getting this CASIL CCM-2040CSL v2.0 LCD going as I was getting registers shifting.
    What is the difference between using a 4 bit bus vs an 8 bit bus? I am trying to use 8 bits 'cause, well I have them. I figured that 8 bits would either give faster communication or some other advantage.
    I am running this on a 16F628 at 20MHz.
    Euh, nevermind...?
    I was testing the 4 vs 8 bit bus technique and it works using 4 bits.
    Oh well, I have 4 spare pins on my PIC.
    Hi robert,
    If i refer to my, i'll get :
    i always use LCD in 4bit mode. This way you save I/O ( duh! ). It can be more faster... it has too but... who will see it??? i think nobody
    Don't forget the LCD Defines... 4 lines and blah blah blah. Be sure you disable analog comparator and place pull-up on RA4 pin.
    In my case i'll place all LCD pins on PORTB. The define lines will look something like this
    '********************** Lcd pinout ******************************
    '                  B0-B3 : Data port
    '                     B4 : Rs Bit
    '                     B5 : E Bit
    define LCD_DREG PORTB   ' Set data pin of LCD to
    define LCD_DBIT 0       ' PORTB.0-PORTB.3
    define LCD_RSREG PORTB  ' Set RS bit of LCD to
    define LCD_RSBIT 4      ' PORTB.4
    define LCD_EREG PORTB   ' Set E bit of LCD to
    define LCD_EBIT 5       ' PORTB.5
    define LCD_LINES 4
    chikyto's Avatar
    chikyto Guest
    Default datasheet
    Hello Robert
    I am writing you for asking about the datasheet of CASIL CCM-2040CSL v2.0 LCD because I have one of this component but I can't find your datasheet.
    Please, can you send me a copy if you have it?
    Sorry by me english, I am studing
    Chikyto
    or
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
    Last Post: - 27th June 2007, 00:07
  4. Controlling LCD contrast?
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 27th December 2006, 03:31
  5. How to change contrast LCD?
    By MCU Destroyer in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 14:16
