Help Getting Started
Results 1 to 11 of 11
    Hi Fred,
    Make sure which "Compile" you are using ICD Compile does not work unless you are using the ICD. PBP generates an INTEL Hex file and that is what your programmer needs to find, and load onto the chip. It generates asm and mac and some others too. All with the filename you chose.
    My comments regarding the 16f628 . . . is due to their not having adcon ansel . . .
    According to the info that came with the compiler, for the 16F series, the IDE automatically uses MPASMWIN
    PBP usually defaults to it's own assembler in MCS to use mpasm you have to change the setting . . . file, view, compiler options, assembler tab, check box use mpasm
    Aug 2009
    SUCCESS !!!
    Thanks everyone for your help. I really appreciate your insights!
    I did use the MPASM switch and it worked. The other thing that I did was send a "manual" erase from the programmer screen and then checked to be sure that the chip was blank before loading my program. I had lights flashing all night!! Now on to my project -
    Thanks AGAIN
    Fred
    <h1> Congratulations !</h1> Feels pretty good huh?
  1. Trying to get started w/ HPWM
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 20th February 2010, 19:42
  2. getting started
    By cunninghamjohn in forum mel PIC BASIC Pro
    Last Post: - 15th November 2008, 19:42
  3. Getting started... again...
    By Neosec in forum mel PIC BASIC Pro
    Last Post: - 31st May 2008, 03:09
  4. How did you get started .....
    By keithdoxey in forum General
    Last Post: - 13th April 2007, 20:29
  5. getting started with a PIC 18F4550
    By bigbear in forum General
    Last Post: - 16th October 2006, 03:31
