Save a port number into the EEPROM?
Results 1 to 7 of 7
    Jan 2008
    Default Save a port number into the EEPROM?
    How can I store a port number into the on chip EEPROM and then read it back and do something like this,
    start:
    High portnumber
    Low portnumber
    goto start
    Not sure I understand what you want.
    Are you wanting to make the whole port high or just have certain pins go high based on a number value?
    Jan 2008
    I want to make a certain pin high based on a number that can be stored into a variable and the EEPROM.
    Here is how to set the variables up. The read/write part is in the manual.
    TRISB = %00000000
    X   VAR BYTE
    X = %00000100
    PORTB = X
    The above will make PORTB.2 high.
    Change "X" and read/write to eeprom.
    Is that what you are after?
    Jan 2008
    Do I understand this right?
    This will make PORTC.6 high?
    TRISC = %00000000
    X   VAR BYTE
    X = %01000000
    PORTB = X
    And this will make PORTC.1 and PORTC.3 high?
    X = %00001010
    PORTB = X
    Yes.
    That is after you change
    PORTB to PORTC
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Save number cell in to EEprom
    By piombazzo in forum GSM
    Last Post: - 18th August 2008, 21:49
  3. Microcontroller with 2 way paging application problem
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
