Thanks for the replies, what i have is a dc motor which only lists its peak power of 350 Watts @ 24 Volts on its rating plate. To conform to legal specs the maximum allowable "continuous "power of the motor equals 200 Watts, this is my dilema, to convert the peak to continuous power to see if this motor complies. I am interesting in finding out how the motor manufacturers come to a continuous rating, being that the peak power can be a multiple of e.g 2 to 5 times continuous power. Under a steady load the motor current will ramp up under start, usually clamped via a controller to improve motor efficiency ratings, then ramp down to zero as the rpm rises to maximum (back emf). Whether the manufacturer maps these figures @ set temperature @ set load and finds the mean value or uses an algorithm containing other data is where I am stuck at.
Many thanks
