Continous power dc motor
Results 1 to 11 of 11
Threaded View
  1. #5
    Nov 2008
    Are you able to run the motor under the given load as a test?
    If so then measure the amps.
    The load will determine the amps.
    My problem is Dave that by the nature of a dc motor the motor current reduces to zero as the rpm increases due to the back emf, so the current is non linear (motor will be at various pwm from 0 to 100). Thus I am not sure how manufacturers come to derive the continuous power. I understand that peak power can be upto 5x continuous power depending on manufacturer, and I cannot work back to the motor constant (to see if their are equivalents) as I am missing peak torque data.
    Thanks for your reply
  1. DC motor parameters estimation !
    By iugmoh in forum General
    Last Post: - 6th June 2008, 18:29
  2. Driving a DC motor /w 16f84a
    By Lilmanmgf in forum mel PIC BASIC Pro
    Last Post: - 15th May 2007, 13:39
  3. Info about Snubbers
    By mikebar in forum Schematics
    Last Post: - 27th April 2007, 09:56
  4. H-Bridge control DC motor
    By Paul F in forum General
    Last Post: - 11th March 2005, 13:50
  5. H-Bridge control DC motor
    Last Post: - 2nd March 2005, 22:04
