Continous power dc motor
Results 1 to 11 of 11
    Nov 2008
    Default Continous power dc motor
    Hello to all, can any kind soul point me in the right direction to measure or mathematically calculate the continuous power of a brushed (dont know if that is relevant or not) dc motor. The motor manufacturer only lists its power output as peak power and does not reply to my queries sent. I have a motor rated at 350 Watts peak which i wish to use in a pic based project but under uk law i am allowed 250 Watts continuous.
    Many thanks for any suggestions
    oscar
    (2 spelling mistakes, old english teacher would go mad)
    anonymouse, W = I x E, or Wattage = Current x Voltage...
    Nov 2008
    Thanks for the reply, I was interested to know how continuous power of a motor is derived (formula perhaps).Is the peak power of a motor measured under un/loaded conditions, if their are other parameters in calculating the continuous power of a motor, i.e derating factors for continous use,heat dissipation etc. Similar factors to working out the csa of a conductor, but using the motors rated peak power as that is all I have to work from.
    cheers
    Are you able to run the motor under the given load as a test?
    If so then measure the amps.
    The load will determine the amps.
    Nov 2008
    My problem is Dave that by the nature of a dc motor the motor current reduces to zero as the rpm increases due to the back emf, so the current is non linear (motor will be at various pwm from 0 to 100). Thus I am not sure how manufacturers come to derive the continuous power. I understand that peak power can be upto 5x continuous power depending on manufacturer, and I cannot work back to the motor constant (to see if their are equivalents) as I am missing peak torque data.
    Thanks for your reply
    May 2008
    Italy
    350 watt seconds (Wsec) is equal to 350 newton meters (N-m)
    Al.
  1. DC motor parameters estimation !
    By iugmoh in forum General
    Last Post: - 6th June 2008, 18:29
  2. Driving a DC motor /w 16f84a
    By Lilmanmgf in forum mel PIC BASIC Pro
    Last Post: - 15th May 2007, 13:39
  3. Info about Snubbers
    By mikebar in forum Schematics
    Last Post: - 27th April 2007, 09:56
  4. H-Bridge control DC motor
    By Paul F in forum General
    Last Post: - 11th March 2005, 13:50
  5. H-Bridge control DC motor
    Last Post: - 2nd March 2005, 22:04
