timer1 trouble
Results 1 to 2 of 2
Thread: timer1 trouble
    beginner10's Avatar
    beginner10 Guest
    Default timer1 trouble
    Hello,
    i'm using a pic16f882 with a 20 Mhz oscillator connected to pin 9 and 10.
    i try to get a timer running with a tick every 0.1 second, but i cannot get it to work.
    What's the problem?
    @ DEVICE PIC16F882,HS_OSC
    DEFINE	OSC 20
    ' Timer1 Registers:
    ' Prescaler=1:8; TMR1 Preset=0; Freq=9,53674Hz; Period=0,1048576 s
    T1CON.5 = 0 ' T1CON.T1CKPS1 = 1 ' bits 5-4  Prescaler Rate Select bits
    T1CON.4 = 0 ' T1CON.T1CKPS0 = 1
    T1CON.3 = 1 ' T1CON.T1OSCEN = 1 ' Timer1 Osc Enable: bit 1=on
    pause 250  'delay for starting oscillator
    T1CON.2 = 1 ' T1CON.T1SYNC  = 1 ' Synchronization Control bit:
    T1CON.1 = 0 ' T1CON.TMR1CS  = 0 ' Source bit: 0=Internal clock (FOSC/4) / 1                                           ' External clock from pin T1CKI
    T1CON.0 = 1 ' T1CON.TMR1ON  = 1 ' bit 0 enables timer
    TMR1H = $0        ' preset for timer1 MSB register
    TMR1L = $0        ' preset for timer1 LSB register
    when I try to read the TMR1H, it's counting like crazy, and keeps overflowing ( thus recounting to 255).
    Thanks in advance
    Hello beginner1,
    T1 is a 16 bit timer so it should overflow at 65535 not 255. Using Mister_E's PICMultiCalc
    you should set your timer so: Preset at 34286, 1:16 prescale, will overflow @ 100.001 mSec
  1. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 12:49
  2. RPM With Timer1
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 29th June 2009, 22:50
  3. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 16:07
  4. Time Period of Timer1
    By arnol34 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 01:31
  5. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 02:24
