LCD Memory Writing
Results 1 to 11 of 11
    Feb 2009
    Southern California
    Default LCD Memory Writing
    I have found several good threads that helped me figure out how to write to the custom characters of an LCD, but I couldn't find anywhere including the data sheets on how often I can write to those memory locations. If I want to do an animation that updates every second, does that mean if I hit 100,000 writes after a day and a half I might start getting corrupted results? Hopefully someone has a better data sheet or has done some long term projects already.
    David
    Matko
    800-814-4053
    Your LCD probably doesn't use EEPROM for storing special characters but dynamic (or static) RAM. This does not have the kind of WRITE limitations that older EEPROM designs had. After all, your PC's RAM is updated thousands of times a second, if it had that kind of limitation your PC wouldn't last more than a minute!
    How can you check whether you have EEPROM or dynamic RAM? Create a custom character, save it to LCD, power off, and check if it's still there a couple of hours later! If it's gone, then you're safe. If it's still there... well... you still might be OK...
    Technology is in a state of continual flux, you have some new PICs on the market today that have many kB of static RAM (the kind that doesn't get erased when you power-off) and which doesn't have the EEPROM life-limit. There's also EEPROM's on the market that last millions of WRITE cycles - not just a 100k.
    So, in summary, what I've written probably won't help you. Your LCD's Datasheet and/or manufacturers technical helpline is a better bet.
    Feb 2009
    Southern California
    Thanks for the help, I'll swap out my LCD with a new one for the day and test the original tomorrow. Thanks for the details explanation.
    David
    May 2007
    ....you have some new PICs on the market today that have many kB of static RAM (the kind that doesn't get erased when you power-off) and which doesn't have the EEPROM life-limit.
    Which PICs have static RAM that doesn't get erased when you power-off?
    May 2007
    Too bad. I had high hopes for this.
    From Micros web site
    Static RAM or SRAM
    Static Random Access Memory. Program memory you can Read/Write on the target board that does not need refreshing frequently.
    Look to you data sheets. Many have SRAM.
    May 2007
    Does the static ram retain its contents when you power off?
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
