early power down
Results 1 to 5 of 5
    If you need more time you can add more/bigger capacitors.
    Or, if you really want to make sure the data is saved and you have the room and an extra PIC pin...
    Run the PIC from a rechargeable battery or battery pack, have the mains keep a float on the battery.
    Rig a MOSFET/transistor/relay as a self holding relay with the PIC doing the holding.
    When the interrupt triggers the PIC can save the data, close the windows and put the cat out. Then shut
    it self down.
    When it is time to start the system have a momentary switch to energize the "relay". If you want it to come on automatically. Add another relay that the mains control to put the initial power to the relay. One the PIC starts it will do the holding.
    Jun 2008
    Varese , Italy
    Thanks Dave,
    Ambrogio
  1. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. PIC power backup with "super capacitor"
    Last Post: - 25th January 2007, 00:51
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
