LCD wont work :(
Results 1 to 17 of 17
    Normally the contrast likes things on the "-" side. If you have a pot wire it like the example in the PBP manual. If not just try it going to the zero rail (-).
    And PORTC 0-3 needs to be digital.
    ANSEL = %00000000
    That should turn all ADC off.
    I think...
    Aug 2009
    ANSEL = %00000000
    I think...
    If I set Vo (contrast) to GND, I wont even get the black squares at start.
    ANSEL = %00000000 <- I try that, no change.
    If I use a voltmeter on PortC 0-3 all are logic low (0volt) idle. In start before the LCD initailized portC 0-3 are logic high (5volt), is that right?
    May 2008
    Italy
    Your diagram in post #8 has the contrast pot wrongly wired. Correct the wiring as per the attached snap. Then adjust the pot till you have clean characters on LCD.
    Al.
    Aug 2009
    Quote Originally Posted by aratti View Post
    Al.
    im not using any pot at all. I have just put the Vo to +5volt with resistor between, if thats wrong I wouldnt seen those black squares, right?
    Having the contrast wired wrong is the reason you see the black squares.
    Having the contrast going to 5+ is wrong. Sometimes going to (-) will work but the best bet is to use a pot like the manual and Al said. Then it is adjustable.
    Aug 2009
    I have just put a pot there, and now I either get black squares or nothing
    Lightbulb
    For a quick contrast setting ... just use the forward voltage of a Si diode ( .5 to .6 v @ 1 mA ) to set Vo ... ( do not work with OLED displays !!! )
    simple and efficient ...
  1. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 07:13
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. cant get my Lcd to work using Pic18f452
    By civicgundam in forum General
    Last Post: - 7th October 2007, 01:13
  5. Why doesn't my code for 18f452 work on 18f252?
    By senojlr in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2005, 03:42
