LCD wont work :(
Results 1 to 17 of 17
    hoi,
    this works with 628 and Sharp LM16A211 at 4Mhz
    2 rows of black squares if disp is not initialised ( at power up)
    init the display first at startup
    rgds
    tb
    pause 2000
    DEFINE LCD_DREG PORTD 'dataport select'
    DEFINE LCD_DBIT 0 'first databit
    DEFINE LCD_RSREG PORTA 'lcd register port
    DEFINE LCD_RSBIT 3 'register select bit'
    DEFINE LCD_EREG PORTA 'enable poort'
    DEFINE LCD_EBIT 1 'enable bit'
    DEFINE LCD_BITS 4 'lcd bus size'
    DEFINE LCD_LINES 2 'lcd lines'
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50 'data delay in µs'
    'init display
    LCDOUT $FE,1 ' clear LCD
    pause 100 ' pauze 0,1s
    LCDOUT $FE,2 ' cursor home
    LCDOUT $FE,$0C ' cursor off
    pause 1000 ' pauze 0,1s
    ' message
    LCDOUT $FE, $80, " hello "
    LCDOUT $FE, $C0, " ready "
    go on
    Aug 2009
    Quote Originally Posted by tiger_bel View Post
    hoi,
    rgds
    tb
    pause 2000
    'init display
    ' message
    go on
    I have try that code, and I cant get it work.
    I have try to switch to a new LCD display, and still same problem.
    Now i have try with PIC16F676, almost the same problem there, but this time the first row is showing black squares on initializing and then clear screen 1 sec later...
    Here is the code for pic16f676:
    @ device INTRC_OSC_NOCLKOUT
    DEFINE LCD_DREG PORTC 'dataport select'
    DEFINE LCD_RSREG PORTC 'lcd register port
    DEFINE LCD_RSBIT 4 'register select bit'
    DEFINE LCD_EREG PORTC 'enable poort'
    DEFINE LCD_EBIT 5 'enable bit'
    CMCON = 7
    VRCON = 0
    Pause 1000
    'init display
    LCDOut $FE,1 ' clear LCD
    Pause 100 ' pauze 0,1s
    flags = 0
    LCDOut $FE,2 ' cursor home
    LCDOut $FE,$0C ' cursor off
    Pause 1000 ' pauze 0,1s
    ' message
    LCDOut $FE, $80, " hello "
    LCDOut $FE, $C0, " ready "
    loopme:
    Pause 1000
    High PORTA.0
    Pause 1000
    Low PORTA.0
    GoTo loopme
    The 676 has ADC on port C. Might help to turn that off.
    How do you have the LCD contrast pin connected?
    you are using 4bit datatransfer to display.
    are the 4 bits connected to DB4 to DB7 on display side ???
    rgds
    tiger_bel
    Aug 2009
    Wiring diagram:
    This is how the LCD display looks like for about 1sek before the screen goes blank again..
    Thanks for all help so far
    Normally the contrast likes things on the "-" side. If you have a pot wire it like the example in the PBP manual. If not just try it going to the zero rail (-).
    And PORTC 0-3 needs to be digital.
    ANSEL = %00000000
    That should turn all ADC off.
    I think...
    Aug 2009
    ANSEL = %00000000
    I think...
    If I set Vo (contrast) to GND, I wont even get the black squares at start.
    ANSEL = %00000000 <- I try that, no change.
    If I use a voltmeter on PortC 0-3 all are logic low (0volt) idle. In start before the LCD initailized portC 0-3 are logic high (5volt), is that right?
  1. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 06:13
  2. Play with LCD on PICDEM
  3. cant get my Lcd to work using Pic18f452
    By civicgundam in forum General
    Last Post: - 7th October 2007, 00:13
  5. Why doesn't my code for 18f452 work on 18f252?
    By senojlr in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2005, 02:42
