What about if you try slower baudrate... as slow as you can ? simple thought here because i solve many of my noise problem with that...
AND NOW let's shrink this part of your code
it has to work but gives you a load of delay IMO.Code:'***************************************** DISABLE TIMER_INTERRUPT: PIR1.0 = 0 TMR1TEMP.LOWBYTE = TMR1L TMR1TEMP.HIGHBYTE = TMR1H TMR1SET=TIMER1PRE+TMR1TEMP TMR1L=TMR1SET.LOWBYTE TMR1H=TMR1SET.HIGHBYTE LCDOUT $FE,$C0 IF DAY = 1 THEN LCDOUT "MON" ENDIF IF DAY = 2 THEN LCDOUT "TUE" ENDIF IF DAY = 3 THEN LCDOUT "WED" ENDIF IF DAY = 4 THEN LCDOUT "THU" ENDIF IF DAY = 5 THEN LCDOUT "FRI" ENDIF IF DAY = 6 THEN LCDOUT "SAT" ENDIF IF DAY = 7 THEN LCDOUT "SUN" ENDIF LCDOUT $FE,$C3 LCDOUT #H2 LCDOUT #H1 LCDOUT ":" LCDOUT #M2 LCDOUT #M1 LCDOUT ":" LCDOUT #S2 LCDOUT #S1 LCDOUT $FE,$CC LCDOUT #REC LCDOUT " " LCDOUT #T2 LCDOUT #T1 RESUME ENABLE
this is my own version
and probably LCDOUT in one shot can also workCode:'***************************************** DISABLE TIMER_INTERRUPT: PIR1.0 = 0 TMR1TEMP.LOWBYTE = TMR1L TMR1TEMP.HIGHBYTE = TMR1H TMR1SET=TIMER1PRE+TMR1TEMP TMR1L=TMR1SET.LOWBYTE TMR1H=TMR1SET.HIGHBYTE LCDOUT $FE,$C0 select case DAY case 1 LCDOUT "MON" case 2 LCDOUT "TUE" case 3 LCDOUT "WED" case 4 LCDOUT "THU" case 5 LCDOUT "FRI" case 6 LCDOUT "SAT" case 7 LCDOUT "SUN" end select LCDOUT $FE,$C3,#H2,#H1,":",#M2,#M1,":",#S2,#S1 LCDOUT $FE,$CC,#REC," ",#T2,#T1 RESUME ENABLE
Code:LCDOUT $FE,$C3,#H2,#H1,":",#M2,#M1,":",#S2,#S1,_ $FE,$CC,#REC," ",#T2,#T1
