variable + decimal
Results 1 to 5 of 5
    Jun 2006
    Default variable + decimal
    I have a variable as word
    XL VAR WORD
    LO VAR XL.LOWBYTE
    HI VAR XL.HIGHBYTE
    and a decimal number.
    How can to add the decimal to variable and after to write to eeprom;
    like this : 13000(variable) + 622,784(decimal - is always the same number) = 13622,784
    The decimal 622,784 is from division 38,924/0,0625
    Bombay, India
    Doing 13000 + 623.4
    is same as doing
    13000*10 + 623.4*10
    =136234
    when you want to recover it, simply divide by 10 to get the result
    =13623.4
    You have to make sure to live within the integer limits of PBP unless you are using the long version PBPL.
    Jun 2006
    I can live with the integer limits of PBP.
    I can not use PBPL because i use pic16f88.
    Wink
    Hi, Savnik
    Is your decimal number a constant ??? ... and could you tell us where it comes from.
    as
    and ALSO the same as ...
    38,924 * 16 !!!
    Jun 2006
    Yes it is a constant number.
    is from : 28,224+10,7 = 38,924 and the 0,0625 is the step
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 00:06
  2. Serin #Variable question
    By bluesmoke in forum mel PIC BASIC Pro
    Last Post: - 7th July 2009, 17:48
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  4. WORD vs BYTE variable lengths
    By bartman in forum General
    Last Post: - 28th November 2005, 21:16
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 20:02
