CANbus
Results 1 to 24 of 24
Thread: CANbus
    Jul 2007
    Bavaria
    Hmm...
    I got $03 $BF $07 for 20MHz and 100kbps from the calculator.
    Furthermore, your CIOCON configuration differs from the one I suggested, try setting it to $20.
    Another idea: I am not sure whether you have to set the DLC register in config mode or if normal mode is possible..
    Apr 2009
    Quote Originally Posted by inse View Post
    Hmm...
    I calculated $03 $BF $07 for 20MHz and 100kbps
    Yes, in my previous post you can see that I've tried also with that values with no luck I'm really frustrated
    Jul 2007
    Bavaria
    For anyone willing to dig into the CAN-bus I conclude this thread:
    ZX81SP finally got his code running - it was a matter of oscillator configuration.
    I have listed the necessary steps for setting up CAN above - except that the CAN Bit timing calculator is available from www.intrepidcs.com, not from Microchip.
    New Jersey
    Default Re: CANbus
    This is about the only useful thread I've found regarding CAN communication. This is way above my level of expertise but I was never one to give up. My objective is to communicate with a locomotive that uses CAN communication.
    Can anyone tell me if I use the same PIC and code above, will it allow me to transmit data on the CAN network? I realize my configurations will probably be different but what about the RX side of the CAN? Will it be easier than the transmit?
    Jul 2007
    Bavaria
    Default Re: CANbus
    Christopher,
    it's hard to give sensible answers as you supply no details about the project.
    Do you know what the communication is going to look like?
    If you are going to setup a bidirectional communication a CAN analyzer will be a very useful tool.
    Ingo
    New Jersey
    Default Re: CANbus
    Glad to see you are still around, Ingo. I will create another thread so I don't hijack this one.
  1. canbus
    By nono2002 in forum mel PIC BASIC
    Last Post: - 1st January 2014, 20:35
  2. Canbus
    By Tobias in forum Off Topic
    Last Post: - 22nd September 2008, 23:54
  3. Using the 18F2480 CAN CANBUS
    By bwarb in forum mel PIC BASIC Pro
    Last Post: - 15th August 2005, 13:45
  4. CANbus
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 17th March 2005, 15:43
