Another point to check just came into my mind:
The PIC you are using has internal PLL - did you check its configuration?
Not sure if this is what you ask for, but I've checked the programmer options, OSC is setting to HS, there is a option for HS w/PLL on but it's not enabled.
Can you verify the BRG values?
