dumb question
Results 1 to 40 of 94
Thread: dumb question
    The default install of Pic Basic Pro is in C:\PBP. That is where you will find all of the *.inc files for PBP.
    Aug 2009
    I cant do it because I have the demo version of PBP,is other way to do that?
    I have not had the demo version for a long time. I think the only thing you cannot do with the demo for the chips it supports is write code over a certain size.
    The install directory might be named something else though, so you will have to look around.
    Aug 2009
    ;*  16F690.INC                                                  *
    ;*  Notice    : Copyright (c) 2006 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 05/23/06                                        *
    ;*  Version   : Demo                                            *
    ;*  Notes     :                                                 *
            NOLIST
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
            NOLIST
            LIST
            '16F690 DEMO_2
      '  DEFINE OSC 8       'Comment the 4Mhz and uncomment these for 8Mhz
      '  OSCCON=%01110000
        DEFINE OSC 4           'This is the default setting
        OSCCON=%01100000
            @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
        TRISC = %00000000   '0 will make the pins an output, 1 will make them inputs
        START:
        PORTC = %00000001
        PAUSE 250
        PORTC = %00000010
        GOTO START
    Results:
    ERROR Line 12: Syntax error.(16F690.INC)
    ERROR Line 13: Redefinition of LABEL NOLIST.(16F690.INC)
    ERROR Line 14: ENDIF without a matching IF..THEN.(16F690.INC)
    Aug 2009
    Did it again.I opened from the open file-16F690.INC and paste your code plus another file where past your code
    ;*  16F690.INC                                                  *
    ;*  Version   : Demo                                            *
    ;*  Notes     :                                                 *
            NOLIST
            NOLIST
            LIST
            '16F690 DEMO_2
      '  OSCCON=%01110000
        OSCCON=%01100000
            @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLR_ON & _CPD_OFF
        START:
        PORTC = %00000001
        PAUSE 250
        PORTC = %00000010
        GOTO START
    First is 16F690.INC second is the code I paste it from you
    '*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 23/08/2009                                        *
    '16F690 DEMO_2
      '  OSCCON=%01110000
        OSCCON=%01100000
        START:
        PORTC = %00000001
        PAUSE 250
        PORTC = %00000010
        GOTO START
    Results:
    ERROR Line 17 : Syntax error.(led.pbp)
    I dont understand nothing,so hard is it to create a code?!?...or I am really dumb?
    You are not following the directions. Go back and read all of the links and post.
    Why do you need the card reader in the first place? Seems like a lot of work.
    Aug 2009
    Maybe you are right that Im not folowing the corect line of instructions,but my english is not so good and were are many explanation I dont get it.Would be easy if somebody could tell me in little words what to folow,I know how stressfull can be when you explain to somebody something and dont get it and you have to explain again and again....Honestly I really dont know were to start from
  1. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  2. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  3. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. Dumb question
    Last Post: - 20th June 2006, 13:02
