dumb question
Results 1 to 40 of 94
Thread: dumb question
    Aug 2009
    I have compiled and anssemblex and importing hex file in pickit2 and write to PIC.with this code only the second Led from the board is blinking and when press buttonthe Led is not blink.
    [code]
    '16F690 DEMO
    ' DEFINE OSC 8 'Comment the 4Mhz and uncomment these for 8Mhz
    ' OSCCON=%01110000
    DEFINE OSC 4 'This is the default setting
    OSCCON=%01100000
    ' @ device pic16F690, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
    'VARS
    LED1 VAR PORTC.0
    LED2 VAR PORTC.1
    START:
    HIGH LED1
    LOW LED2
    PAUSE 250
    LOW LED1
    HIGH LED2
    PAUSE 250
    GOTO START
    [code]
    The 2 code dont work
    [code]
    '16F690 DEMO_2
    ' OSCCON=%01110000
    OSCCON=%01100000
    'The first line is if you are using PM, the second if you are using MPASAM
    TRISC = %00000000 '0 will make the pins an output, 1 will make them inputs
    START:
    PORTC = %00000001
    PAUSE 250
    PORTC = %00000010
    GOTO START
    [code]
    I get this errors:
    Error LED2.ASM 45 : [225] undefined symbol 'osccon'
    ---------------46-------------------------'trisc'
    ---------------49-------------------------'portc'
    Fatal----------49 : [300] too many errors
    Did you comment the lines in the 16F690.inc file that is in the PBP directory? Like the config thread pointed out.
    In MCS do you have the box checked to use MPASM?
    Aug 2009
    Angry
    In MCS box in unchecked,and where do I find the .inc file of PIC16F690?
    The default install of Pic Basic Pro is in C:\PBP. That is where you will find all of the *.inc files for PBP.
    Aug 2009
    I cant do it because I have the demo version of PBP,is other way to do that?
    I have not had the demo version for a long time. I think the only thing you cannot do with the demo for the chips it supports is write code over a certain size.
    The install directory might be named something else though, so you will have to look around.
    Aug 2009
    ;*  16F690.INC                                                  *
    ;*  Notice    : Copyright (c) 2006 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 05/23/06                                        *
    ;*  Version   : Demo                                            *
    ;*  Notes     :                                                 *
            NOLIST
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
            NOLIST
            LIST
            '16F690 DEMO_2
      '  OSCCON=%01110000
        OSCCON=%01100000
            @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
        START:
        PORTC = %00000001
        PAUSE 250
        PORTC = %00000010
        GOTO START
    Results:
    ERROR Line 12: Syntax error.(16F690.INC)
    ERROR Line 13: Redefinition of LABEL NOLIST.(16F690.INC)
    ERROR Line 14: ENDIF without a matching IF..THEN.(16F690.INC)
  1. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  2. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  3. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. Dumb question
    Last Post: - 20th June 2006, 13:02
