dumb question
Results 1 to 40 of 94
Thread: dumb question
    Aug 2009
    Yes,PIC16F690.Im reading.....
    Aug 2009
    So basicly if Im using MPLAB IDE and MPASM as assembler this tools will be located in the MPLAB IDE folder under the aplication Maestro?
    For now use Micro Code Studio and MPASAM as the assembler. I am hearing about problems with MPLAB right now.
    The file you need to comment the lines in is in the PBP directory.
    Assuming you have the 16F690.inc file commented on the correct lines like the above thread shows... This code should have a couple LEDs blinking.
    '16F690 DEMO
      '  DEFINE OSC 8       'Comment the 4Mhz and uncomment these for 8Mhz
      '  OSCCON=%01110000
        DEFINE OSC 4           'This is the default setting
        OSCCON=%01100000
        'The first line is if you are using PM, the second if you are using MPASAM
      '  @ device  pic16F690, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
        @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
        'VARS
        LED1    VAR PORTC.0
        LED2    VAR PORTC.1
        START:
        HIGH LED1
        LOW  LED2
        PAUSE 250
        LOW  LED1
        HIGH LED2
        PAUSE 250
        GOTO START
    This should do the same as the above code but in a different way.
    '16F690 DEMO_2
      '  OSCCON=%01110000
        OSCCON=%01100000
        TRISC = %00000000   '0 will make the pins an output, 1 will make them inputs
        START:
        PORTC = %00000001
        PAUSE 250
        PORTC = %00000010
        GOTO START
    I do not have the demo board that you have, so I hope I did not make a mistake.
    Play with these and look in the manual to see how to add a button for an input.
    Then change things so when the button is pressed the LEDs blink differently.
    Aug 2009
    Ok,I think we miss a lesson first of this:how to use Micro Code Studio,how compiling a file and how convert it to hex files and after load it to chip
    Aug 2009
    I compile that code with Micro Code Studio and
    at the first cod only blink Led no2 on the board without pressing nothing
    at the second code stay On Led no1 without pressing nothing
    and in the compiler I got this error when compiling
    Error LED2.ASM 49 : [235] opcode expected instead of '_config
    Im using Micro Code Studio with PICBASIC PRO Compiler Demo
    In MCS on the toolbar click View then go to Compiler and program options. Then go to the Assembler tab. You pick MPASAM there. If the box is unchecked then PM is used.
    Aug 2009
    Ok done that,have you read my previsious post before posting?I did compile it with PM,got some errors in it but at the end got some results
    Using PM.
    Did you change the code to work with PM. The way I have it posted it is for MPASM.
    Maybe I confused things the way I did it. I was wanting to show both ways.
  1. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  2. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  3. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. Dumb question
    Last Post: - 20th June 2006, 13:02
