ok,thank you,got it now.witch will be the best 512kb EEPROM to use?24C512 or 24LC512?whats the diference between these 2?and also witch will be the 8pin based best PIC to use?12F675 or 12F683?Or you recomend something else?Thank you
You must chose a PIC with enough pins for your F2F devices, two pins for the EEPROM (C or LC still require two lines regardless which one you chose), and however many additional pins for external communications or other connections. Remember one of the pins on the 12F675/683 is INPUT ONLY that leaves five I/O's. If you are going to use Serial Communications (like RS232) then you WILL need a Crystal or Resonator, that will use up two pins, and three I/O's may then be insufficient for your needs.
As regarding EEPROMS... the 'C' device is a plain SERIAL device requiring something like SHIFTIN/SHIFTOUT usage, whereas the 'LC' is an I2C BUS device requiring I2CWRITE/I2CREAD usage.
Thank you Melanie for your answer I got it now.Where can I find a schematic or something to test that,or who could give me an advice on how to built this?
Which way do you want to go?
If you go with the I2C method then take a look at the PBP manual. There is enough information there to get you started.
The section in the manual about shiftin/out along with a data sheet will also get you started in that direction.
Let us know the parts you plan on using.
Well,first I need a schematic,and I also would like to know if the F2F decoding can be done inside a PIC(16f628, 16f84 etc.) to make it as simply is posibile.So,can the F2F decoding be done inside a pic and witch series of EEPROM to use for that,24C512 or 24LC512?
So can I order any of these PICs mentioned?And I will look what EEPROM I can find.Interfacing PIC with EEPROM and in the schematic need also some resistors and capacitors?witch one and how many?Thanks
EEPROM Schematic Information and example code is contained in your MeLabs PBP Manual that came with your PICBasic compiler.
Just curious...
Is this your first project?
I ordered the Pic Kit 2 already,have to get it this days,and yes,this is my first project and any help from you will be apreciated,so sory if sometime(or always?) I make some dumb questions
