dumb question
Results 1 to 40 of 94
Thread: dumb question
    Aug 2009
    Thank you Melanie for your answer,very kind of you.Another question then,can you program an eeprom to do that and exclude the pic from ecuation or not?
    Like Melanie said.
    An EEPROM can not act on it's own. You need something to give it instructions. It is just a storage device. Like a hard drive. Alone it is not much good.
    Aug 2009
    ok,thank you,got it now.witch will be the best 512kb EEPROM to use?24C512 or 24LC512?whats the diference between these 2?and also witch will be the 8pin based best PIC to use?12F675 or 12F683?Or you recomend something else?Thank you
    You must chose a PIC with enough pins for your F2F devices, two pins for the EEPROM (C or LC still require two lines regardless which one you chose), and however many additional pins for external communications or other connections. Remember one of the pins on the 12F675/683 is INPUT ONLY that leaves five I/O's. If you are going to use Serial Communications (like RS232) then you WILL need a Crystal or Resonator, that will use up two pins, and three I/O's may then be insufficient for your needs.
    As regarding EEPROMS... the 'C' device is a plain SERIAL device requiring something like SHIFTIN/SHIFTOUT usage, whereas the 'LC' is an I2C BUS device requiring I2CWRITE/I2CREAD usage.
    Aug 2009
    Thank you Melanie for your answer I got it now.Where can I find a schematic or something to test that,or who could give me an advice on how to built this?
    Aug 2009
    No one wants to help me?
    Which way do you want to go?
    If you go with the I2C method then take a look at the PBP manual. There is enough information there to get you started.
    The section in the manual about shiftin/out along with a data sheet will also get you started in that direction.
    Let us know the parts you plan on using.
    Melanie already answered this...
    Look at the last few pages of the PIC's data sheet. The info you seek is there
    a differance in package, some like surface, some like dips.
    Aug 2009
    So can I order any of these PICs mentioned?And I will look what EEPROM I can find.Interfacing PIC with EEPROM and in the schematic need also some resistors and capacitors?witch one and how many?Thanks
    EEPROM Schematic Information and example code is contained in your MeLabs PBP Manual that came with your PICBasic compiler.
  1. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 17:39
  2. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 22:02
  3. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
  5. Dumb question
    Last Post: - 20th June 2006, 12:02
