PIC BASIC TLC5940 code
Results 1 to 10 of 10
    Aug 2009
    Just a guess.
    Try
    pulsout XLAT
    shiftout SER, SCLK, 1, [4000]
    I have not read the data sheet or tried your device. But the above works for other shift registers.
    Isn't turning a pin HIGH and then LOW the same as PULSOUT?
    I've worked a bunch with other shift registers, but mostly they were binary state (ON or OFF). This is the first time I'm working with a PWM chip so I'm a little confused on how to shift out that much information and in what order it needs to be done..
    I think is has more to do with when the latch is made high. I think it needs done just before the data is sent each time.
    Like I said, just a guess. Give it a try. Might get lucky.
    Aug 2009
    Thanks. Tried it out but I guess I'm not that lucky.
    I think it has to do with how I'm following the Timing Chart?
    Here is the Arduino I'm trying to convert to Basic.
    /*Ti 5940 16-port LED driver
    = overlapped fade across 16 LEDs at a low background level
    * Peter Mackey June 2007 Pratt Digital Arts [email protected]
    * direct adressing to PORTB, smooth flickerless fading (thanks to Amp on the Arduino forum)
    * additional logic from David Cuartielles's & Marcus Hannerstig's LEDdriver demo
    = see the TLC5940 data sheet for the logic behind these pulse sequences
    //using the pin codes on the TLC5940NT to name the Arduino ports
    #define VPRG 2 //"chip pin 27 to Arduino pin 2"
    #define SIN 3
    #define SCLK 7
    #define XLAT 4
    #define BLANK 5
    #define DCPRG 6
    #define GSCLK 8 //note: but using PORTB method
    #define MSINTRVL 0 //could be used to delay updating of incrementFades()
    #define FADEMIN 100 //lowest fade level LEDs will reach (min would be 0, max 4065)
    #define FADEINCR 64 //determines how many steps it takes to run the desired range (lower=longer)
    int fadeLevel[] = {
    0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; //stores a level for each of 16 ports
    int faderNdx = 0; //counter used in this fading sequence
    int fadeState[] = {
    1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; //stores the direction of fading for each port 1,0,-1
    //start with first port
    int next; //used for limit checking in fading function
    float prevMillis; //used for a timing delay
    int word[] = {
    0,0,0,0,0,0,0,0,0,0,0,0}; //temp storage for reversing bits in a word (for greyscale setting)
    void setup() {
    pinMode(VPRG, OUTPUT);
    pinMode(SIN, OUTPUT);
    pinMode(SCLK, OUTPUT);
    pinMode(XLAT, OUTPUT);
    pinMode(BLANK, OUTPUT);
    pinMode(DCPRG, OUTPUT);
    pinMode(GSCLK, OUTPUT); //could also set DDRB directly
    beginSerial(9600); //in case of debugging
    Serial.println("Ready...");
    preset(); //input 'Dot Correction' data
    void loop () {
    setGreys();
    feedPorts();
    if (millis() > (prevMillis+MSINTRVL)){
    incrementFades();
    prevMillis=millis();
    void incrementFades() {
    //a very particular sequence: fade up from LED 0 to 15 then fade down in same direction
    //overlaps incoming&outgoing adjacent ports' fade level
    for (faderNdx=0; faderNdx<=15; faderNdx++) {
    if (fadeState[faderNdx]!=0) { //if the state for this LED is not 0...
    if (fadeState[faderNdx]==1) { //then fade up...
    next = fadeLevel[faderNdx]+FADEINCR;
    if (next<4095) {
    fadeLevel[faderNdx] = next; //...by incrementing the value in the fadeLevel array
    else { //set the state for this LED to fade down
    fadeLevel[faderNdx] = 4095; //be sure is at "max level"
    fadeState[faderNdx] = -1; //flip my sign
    //AND...make next neighbor begin a fade up
    if (faderNdx<15) {
    fadeState[faderNdx+1] = 1;
    else {
    fadeState[0] = 1;
    } //end fading up
    else { //fade down instead...........................
    next = fadeLevel[faderNdx]-FADEINCR;
    if (next>=FADEMIN) { //-----------------
    else {
    //set me to fade down
    fadeLevel[faderNdx] = FADEMIN; //be sure at minimum level
    fadeState[faderNdx] = 0; //stop fading me until neighbor sets me to fade up
    }//end fading down
    }//end check for state not 0
    }// end of cycle thru each port
    //=======5940 control======================================
    void setGreys() {
    //data for each port (12 bit word * 16 ports =192 bits in this loop)...
    //read the fadeLevel array
    for (int i=15; i>=0; i--) { // ports, count DOWN
    int datb = fadeLevel[i];
    //load fade level bits into the temp array BACKWARDS
    for (int j=11; j>=0; j--) {
    word[j]=(datb & 1); //& bitwise AND
    datb >>= 1; //shift right and assign
    // (maybe there's a slicker way to do this!? but this works...)
    //send the data to the 5940
    for (int j=0; j<12; j++) {
    digitalWrite(SIN,word[j]);
    pulseSCLK();
    digitalWrite(XLAT, HIGH);
    digitalWrite(XLAT, LOW);
    void feedPorts() {
    //The actual sequencing of the PWM data into the LEDs, must do constantly...
    digitalWrite(BLANK, HIGH);
    digitalWrite(BLANK, LOW); //=all outputs ON, start PWM cycle
    for (int i=0; i<4096; i++) {
    pulseGSCLK();
    //DOT CORRECTION...do once
    void preset() {
    //Input 'DotCorrex' Data
    //16 outputs, 64 posssible levels of adjustment, 6 bits/chan = 96 bits total
    //[use if any LEDs in array are physically too bright]
    digitalWrite(DCPRG, HIGH); //leaving it H is my arbitrary choice (="write to register not EEPROM")
    digitalWrite(VPRG, HIGH); //=inputting data into dot correx register
    digitalWrite(BLANK, HIGH); //=all outputs off, when this goes high it resets the greyscale counter
    digitalWrite(SIN, LOW); //to start dot correction
    //begin loading in the dot correx data, most significant bit first...
    //but here we are not correcting anything, so LSB is going first!
    for (int i=0; i<16; i++) { //16 ports
    for (int j=0; j<6; j++) { //6 bits of data for each port
    digitalWrite(SIN, HIGH); //for now, 111111 for everybody
    pulseSCLK();
    //----doing the FIRST GREYSCALE SETTING here becuz of the unique 193rd clock pulse
    digitalWrite(XLAT, HIGH); //latch the dot data into the dot correx register
    digitalWrite(VPRG, LOW); //entering greyscale mode
    int datb = 4095; //using same fade level for all ports this first time
    for (int j=0; j<12; j++) { //data for each port, all the same value to start
    digitalWrite(SIN, datb & 01);
    pulseSCLK();
    datb>>=1;
    digitalWrite(XLAT, HIGH); //latch the greyscale data
    pulseSCLK(); //193rd clock pulse only need to do the FIRST time after dot correx
    digitalWrite(BLANK, LOW); //=all outputs ON, start PWM cycle... moved here
    //SCLK used in dot correx and greyscale setting
    void pulseSCLK() {
    digitalWrite(SCLK, HIGH);
    digitalWrite(SCLK, LOW);
    void pulseGSCLK() {
    //ultra fast pulse trick, using digitalWrite caused flickering
    PORTB=0x01; //bring PORTB0 high (pin 8), other ports go low [0x01 does only pin 8, 0x21 also lifts pin 13]
    //16nanosecs is the min pulse width for the 5940, but no pause seems needed here
    PORTB=0x20; //keep pin13 high [0x00 would be all low]
    Grayscale values are 12-bits, and you need to send 16 of those values before latching the data, for a total of 192 bits.
    The code in the attachment is sending 1,536 bits (16*12*8).
    And the method you showed in post #1 would only send 128 (16*8).
    And your variable sizes aren't right. fade is a BYTE array, and can't hold 12-bit values. data1 is also a BYTE array, but you're using it like a WORD variable.
    I think something like this will work better ...
    fade   var WORD[16]
    TempW  var WORD
    setGreys:
        for z = 0 to 15
            TempW = fade(z)
            shiftout ser, sclk, 1, [TempW\12]
        next z
        high xlat
        low xlat
    Then you could ...
    RampCount  var WORD
    ChanCount  var BYTE
    RampUP:
        FOR RampCount = 0 to 4088 STEP 8
            FOR ChanCount = 0 to 15
                fade(ChanCount) = RampCount
            NEXT ChanCount
            GOSUB setGreys
            PAUSE 50
        NEXT RampCount
    RampDN:
        FOR RampCount = 4088 to 0 STEP -8
            NEXT ChanCount
            GOSUB setGreys
            PAUSE 50
        NEXT RampCount
    Dot correction values are 6-bits. 16 of those would total 96-bits.
    Aug 2009
    Thanks for the help with the variable settings. This definitely helps as I'm sure I'm shifting out the right bits now.
    I'm still not getting any response from the TLC5940 though. Now instead of randomly blinking LEDs it's just staying off. I think this is fine because I'm shifting out the right bits, but I'm still confused with the ordering of the LATCH, BLANK, SER.
    If you look at the Timing Chart in the spec sheet they show the ordering, but there is this weird thing where they have a separate pulse GSCLK in addition to the main SCLK pulse. I'm not sure why they have this and I don't know how I'm supposed to do both at the same time..
    Sep 2003
    INDIA
    Default Any luck !
    Take a look at this forum topic , maybe it can help you understand the logic of sending data to the chip.
    http://www.picaxeforum.co.uk/showthr...?t=8616&page=3
    let us know when you succeed.
    Aug 2009
    Default good info
    Hey thanks for that link. That's some really good info. I had to to put this chip on hold because I got swamped with other things, but I was actually going to go back at it this week. This info thread you posted will help.
    I'll post my results (or non-results) later on this week.
    Thanks.
  1. Making Program Code Space your playground...
  2. pic Basic Pro 2.50a & debug statement
    By Phil Moore in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 09:41
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 00:52
  4. Replies: 5
    Last Post: - 17th January 2006, 19:26
  5. Help with MPASM and PIC Basic
    By johngb in forum mel PIC BASIC Pro
    Last Post: - 21st February 2003, 13:07
