Yes, it's twice as fast!
Twice as many pins used or twice as fast. Take your pick.
and their i was thinking it used a more 'usefull' ASCII table... perhaps an EECII table... (English Enhansed Code for Information Interchange)...
Lol![]()
Can someone help me to debug this problem?
Above LCD with above PIC have been conected and programmed...
the LCD displays absolutly nothing not even at power on...
I have purchased two identical and neither display anything at power on...
I have a 38K serial2 going to a com port on my PC which works perfectly...
i'm using all 8 data bits connected to PORT D...
RS (pin 4) is connected to PORTC.5
RW (pin 5) is connected to PORTC.6
E (pin6) is connected to PORTC.7
Contrast is connected to +5V via 1.5K resister
My defines are as follows...
TRISC and D are set to all outputs, i don't know if this is correct or not?DEFINE LCD_DREG PORTD 'LCD data port
DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
DEFINE LCD_RSREG PORTC 'LCD register select port
DEFINE LCD_RSBIT 5 'LCD register select bit
DEFINE LCD_EREG PORTC 'LCD enable port
DEFINE LCD_EBIT 7 'LCD enable bit
DEFINE LCD_RWREG PORTC 'LCD read/write port
DEFINE LCD_RWBIT 6 'LCD read/write bit
DEFINE LCD_BITS 8 'LCD bus size 4 or 8
DEFINE LCD_LINES 2 'Number lines on LCD
DEFINE LCD_COMMANDUS 2000 'Command delay time in us
DEFINE LCD_DATAUS 50 'Data delay time in us
I think their is 'some' activity on the LCD data and controll lines but i only have a digital multimeter so, can't be sure.
I'm using PORTA and E for analogue, PWM 0 and 1 (RC1 and RC2), TMR1 in counter mode using PORTC0 as input and PORTB for digital output and SER2 PC telemetry link...
I have no idea where to begin to find the problem, so any help appreciated...
Try the contrast like the example in the PBP manual. That is the safest way for unknown displays. Normally the contrast likes a little more - than + .
Another thing to double check is if the data lines are in the correct order when connecting to the PIC.
I'll try the contrast in the morning, i think i got a 10K pot somewhere...
I just wrote a simple "hello world" type LCD test program...
I loadedit into oshonsoft's pic simulator and configured it's LCD module...
Acording to the microcontroller view, all the data lines switch to outputs...
However, it gets into a loop with nothing displayed in the LCD module, and tmr1 prescaler is continueously counting up by 1 each loop but over flows without a change in instructions...
:edit after about 17000us in simulation RD0, RD1,RD5 and RD4 to high... still nothing on LCD module
:edit after 22000us in simulation it has now started putting charecters on the LCD...
Just for giggles, can we see the whole code?
