2x16 LCD Module with HD44780 + 16F877A
Results 1 to 13 of 13
    Yes, look in your PBP manual and read about defining the LCD.
    Here is an example (for a different PIC)
        DEFINE LCD_DREG     PORTG
        DEFINE LCD_DBIT     0
        DEFINE LCD_RSREG    PORTE
        DEFINE LCD_RSBIT    0
        DEFINE LCD_EREG     PORTE
        DEFINE LCD_EBIT     1
        DEFINE LCD_BITS     4
        DEFINE LCD_LINES    4
        DEFINE LCD_COMMANDUS    3000
        DEFINE LCD_DATAUS   150
    DREG has to be all on the same port, either upper or lower. DT has a LCD ANY PIN trick someplace if if you are adventurous
    ahhh, yes, i remember reading about those now...
    thanks dave
    Is their any speed advantage to using 8 bits instead of 4?
    thanks
    Yes, it's twice as fast!
    Twice as many pins used or twice as fast. Take your pick.
    and their i was thinking it used a more 'usefull' ASCII table... perhaps an EECII table... (English Enhansed Code for Information Interchange)...
    Lol
    Can someone help me to debug this problem?
    Above LCD with above PIC have been conected and programmed...
    the LCD displays absolutly nothing not even at power on...
    I have purchased two identical and neither display anything at power on...
    I have a 38K serial2 going to a com port on my PC which works perfectly...
    i'm using all 8 data bits connected to PORT D...
    RS (pin 4) is connected to PORTC.5
    RW (pin 5) is connected to PORTC.6
    E (pin6) is connected to PORTC.7
    Contrast is connected to +5V via 1.5K resister
    My defines are as follows...
    DEFINE LCD_DREG PORTD 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTC 'LCD register select port
    DEFINE LCD_RSBIT 5 'LCD register select bit
    DEFINE LCD_EREG PORTC 'LCD enable port
    DEFINE LCD_EBIT 7 'LCD enable bit
    DEFINE LCD_RWREG PORTC 'LCD read/write port
    DEFINE LCD_RWBIT 6 'LCD read/write bit
    DEFINE LCD_BITS 8 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    TRISC and D are set to all outputs, i don't know if this is correct or not?
    I think their is 'some' activity on the LCD data and controll lines but i only have a digital multimeter so, can't be sure.
    I'm using PORTA and E for analogue, PWM 0 and 1 (RC1 and RC2), TMR1 in counter mode using PORTC0 as input and PORTB for digital output and SER2 PC telemetry link...
    I have no idea where to begin to find the problem, so any help appreciated...
  1. 2x16 lcd not working with pic16f72
    By vu2iia in forum Schematics
    Last Post: - 16th February 2011, 14:59
  2. 2x16 lcd problem
    By k3v1nP in forum mel PIC BASIC
    Last Post: - 30th October 2008, 04:46
  3. Play with LCD on PICDEM
  4. PIC16F684 + 8*2 LCD module
    Last Post: - 5th March 2008, 23:38
  5. Lcd 16f877a Heeeeelp!!!
    By chip15 in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 11:51
