2x16 LCD Module with HD44780 + 16F877A
Results 1 to 13 of 13
    Default 2x16 LCD Module with HD44780 + 16F877A
    i've just baught the above LCD from a well known auction site (not sure if i'm allowed to say what)...
    All the searches i've done point to LCD data lines on portA and IO on portB...
    on the 16F877A, PortA and PortE are analogue and i'm using the analogue ports...
    Can i change (somewhere) what pins the LCD is connected to and still use LCDOUT and LCDIN?
    Yes, look in your PBP manual and read about defining the LCD.
    Here is an example (for a different PIC)
        DEFINE LCD_DREG     PORTG
        DEFINE LCD_DBIT     0
        DEFINE LCD_RSREG    PORTE
        DEFINE LCD_RSBIT    0
        DEFINE LCD_EREG     PORTE
        DEFINE LCD_EBIT     1
        DEFINE LCD_BITS     4
        DEFINE LCD_LINES    4
        DEFINE LCD_COMMANDUS    3000
        DEFINE LCD_DATAUS   150
    DREG has to be all on the same port, either upper or lower. DT has a LCD ANY PIN trick someplace if if you are adventurous
    ahhh, yes, i remember reading about those now...
    thanks dave
    Is their any speed advantage to using 8 bits instead of 4?
    thanks
    Yes, it's twice as fast!
    Twice as many pins used or twice as fast. Take your pick.
    and their i was thinking it used a more 'usefull' ASCII table... perhaps an EECII table... (English Enhansed Code for Information Interchange)...
    Lol
    Can someone help me to debug this problem?
    Above LCD with above PIC have been conected and programmed...
    the LCD displays absolutly nothing not even at power on...
    I have purchased two identical and neither display anything at power on...
    I have a 38K serial2 going to a com port on my PC which works perfectly...
    i'm using all 8 data bits connected to PORT D...
    RS (pin 4) is connected to PORTC.5
    RW (pin 5) is connected to PORTC.6
    E (pin6) is connected to PORTC.7
    Contrast is connected to +5V via 1.5K resister
    My defines are as follows...
    DEFINE LCD_DREG PORTD 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTC 'LCD register select port
    DEFINE LCD_RSBIT 5 'LCD register select bit
    DEFINE LCD_EREG PORTC 'LCD enable port
    DEFINE LCD_EBIT 7 'LCD enable bit
    DEFINE LCD_RWREG PORTC 'LCD read/write port
    DEFINE LCD_RWBIT 6 'LCD read/write bit
    DEFINE LCD_BITS 8 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    TRISC and D are set to all outputs, i don't know if this is correct or not?
    I think their is 'some' activity on the LCD data and controll lines but i only have a digital multimeter so, can't be sure.
    I'm using PORTA and E for analogue, PWM 0 and 1 (RC1 and RC2), TMR1 in counter mode using PORTC0 as input and PORTB for digital output and SER2 PC telemetry link...
    I have no idea where to begin to find the problem, so any help appreciated...
    Try the contrast like the example in the PBP manual. That is the safest way for unknown displays. Normally the contrast likes a little more - than + .
    Another thing to double check is if the data lines are in the correct order when connecting to the PIC.
    I'll try the contrast in the morning, i think i got a 10K pot somewhere...
    I just wrote a simple "hello world" type LCD test program...
    I loadedit into oshonsoft's pic simulator and configured it's LCD module...
    Acording to the microcontroller view, all the data lines switch to outputs...
    However, it gets into a loop with nothing displayed in the LCD module, and tmr1 prescaler is continueously counting up by 1 each loop but over flows without a change in instructions...
    :edit after about 17000us in simulation RD0, RD1,RD5 and RD4 to high... still nothing on LCD module
    :edit after 22000us in simulation it has now started putting charecters on the LCD...
    Just for giggles, can we see the whole code?
    @ device pic16F877A, HS_OSC
    @ device WDT_OFF
    @ device PWRT_OFF
    @ device BOD_OFF
    @ device LVP_OFF
    @ device WRT_OFF
    @ device CPD_OFF
    @ device DEBUG_OFF
    Define  OSC				4						' Set clock speed
    DEFINE  SER2_BITS		8						' Ser2 number of data bits
    'Pause 1000
    loop:
    LCDOUT $FE, 1, 2, "INITIALISING"
    LCDOUT $FE, $C0, "Hello"
    goto loop
    Found it... looks like the contrast likes to be fully negative...
    Thanks for the help... Iactualy thaught the contrast should be more positive acording to all the scmatics i looked at...
  1. 2x16 lcd not working with pic16f72
    By vu2iia in forum Schematics
    Last Post: - 16th February 2011, 15:59
  2. 2x16 lcd problem
    By k3v1nP in forum mel PIC BASIC
    Last Post: - 30th October 2008, 05:46
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. PIC16F684 + 8*2 LCD module
    Last Post: - 6th March 2008, 00:38
  5. Lcd 16f877a Heeeeelp!!!
    By chip15 in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:51
