A/D converter problem
Results 1 to 6 of 6
    Hi Melanie,
    Thanks for the advise. A reed relay disconnecting the input will do the job. I got one from local electronics supplier. It is 100v 0.5A 500Om coil. I tried to drive it directly of Pic’s pin and it works well. I attached the oscillogram.
    Just remember that if it hasn't got a built-in Diode to protect against back-emf spikes, you must add one otherwise you will run the risk of destroying the PIC pin that the coil is connected to.
    USA - Arizona
    For multiple inputs you can look at analog switches (e.g. MAX312 and equivalents). These will require a few additional parts to guarantee the power-up conditions (e.g. pull-ups or pull-downs on control lines).
    Just found one more solution reading this thread http://www.picbasic.co.uk/forum/show...hlight=jswayze
    I put 10k resistor in series with the AD pin and changed the PIC to 12F683 or 16F684 (it doesn’t work with 16HV785).
  1. Replies: 9
    Last Post: - 31st July 2008, 08:56
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 16:26
  3. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
  4. A/D converter with pic16f84, i need a help
    By micro in forum General
    Last Post: - 13th December 2005, 21:17
  5. help with pic16f870 a/d converter
    By cammo in forum mel PIC BASIC
    Last Post: - 22nd March 2005, 05:16
